The sonoff stick was defect so I bought a new one and Home Assistant recognize it again but I have still an issue with the Zigbee2MQTT Addon.
Mosquito Broker is started.
Zigbee2MQTT Addon (Current version: 1.29.1-1) started automaticly but I cannot open the Addon and cannot stop the Addon too. When I click on restart then I will receive the following protocol:
[14:24:48] INFO: Preparing to start…
[14:24:48] INFO: Socat not enabled
[14:24:49] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2023-09-29 14:24:50: Logging to console and directory: ‘/config/zigbee2mqtt/log/2023-09-29.14-24-50’ filename: log.txt
Zigbee2MQTT:info 2023-09-29 14:24:50: Starting Zigbee2MQTT version 1.29.1 (commit #unknown)
Zigbee2MQTT:info 2023-09-29 14:24:50: Starting zigbee-herdsman (0.14.83)
Zigbee2MQTT:info 2023-09-29 14:24:53: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-09-29 14:24:53: Coordinator firmware version: ‘{“meta”:{“maintrel”:"3 ",“majorrel”:“6”,“minorrel”:“10”,“product”:8,“revision”:“6.10.3.0 build 297”},“type”:“EZSP v8”}’
Zigbee2MQTT:info 2023-09-29 14:24:53: Currently 32 devices are joined:
Zigbee2MQTT:info 2023-09-29 14:24:53: Tisch Raum (0x00178801096f206e): 929001953101 - Philips Hue White and Color Ambiance GU10 (Router)
Zigbee2MQTT:info 2023-09-29 14:24:53: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2023-09-29 14:24:53: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:warn 2023-09-29 14:25:12: Device ‘Bewegungsmelder Flur’ left the network
Zigbee2MQTT:error 2023-09-29 14:25:26: MQTT error: connect ECONNREFUSED 172.30.33.5:1883
Zigbee2MQTT:error 2023-09-29 14:25:26: MQTT failed to connect, exiting…
Zigbee2MQTT:info 2023-09-29 14:25:26: Stopping zigbee-herdsman…
Zigbee2MQTT:info 2023-09-29 14:25:26: Stopped zigbee-herdsman
But under information is marked with green and I have the possibility to click on Stop or Restart (but stop doesnot work)
I receive the following error description when opening the Addon:
The add-on doesn’t seem to be ready yet, maybe it is still starting. Do you want to try again?
When I click on try again then it will not work too.
Does anyone have an idea and can support me with my issue?
I can’t remember that I have specific login data for Mosquitto.
How can I check this?
That is the protocol from Mosquitto:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[17:07:37] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[17:07:37] INFO: Starting NGINX for authentication handling…
[17:07:38] INFO: Starting mosquitto MQTT broker…
2023-09-29 17:07:38: Warning: Mosquitto should not be run as root/administrator.
2023-09-29 17:07:38: mosquitto version 2.0.11 starting
2023-09-29 17:07:38: Config loaded from /etc/mosquitto/mosquitto.conf.
2023-09-29 17:07:38: Loading plugin: /usr/share/mosquitto/go-auth.so
2023-09-29 17:07:38: ├── Username/password checking enabled.
2023-09-29 17:07:38: ├── TLS-PSK checking enabled.
2023-09-29 17:07:38: └── Extended authentication not enabled.
2023-09-29 17:07:38: Opening ipv4 listen socket on port 1883.
2023-09-29 17:07:38: Opening ipv6 listen socket on port 1883.
2023-09-29 17:07:38: Opening websockets listen socket on port 1884.
2023-09-29 17:07:38: Error: Unable to create websockets listener on port 1884.
[15:07:38] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
[15:07:38] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Thanks so far, the user was deactivated. I activate the user now but when I click on devices > Mosquitto > Configuration > Re-Configure MQTT: Then the user and password is maintained correctly but when I click on ok then an error message appears: Please enter the connection information of your MQTT broker. Connection failed.
