'AddonManager.install' blocked from execution, system is not healthy - setup
When I try to install new addons this is what I get.
Tried several SSH commands (ha su repair, restart, reboot etc.) but nothing helps.
I am running Ha OS on a RPi 4
I hope someone can help me.
Have a look under “Settings ? System > Repairs > kebab (3 dots) > System Information”. I believe it tells you why it’s unhealthy there.
Hi Michael,
Thank you for your response.
There was nothing under system > repairs.
Strange thing was that the time and date where off 6 months.
I broke my SD card and installed a (old) backup. But it kept going wrong.
Ended up to built everything from scratch again.
It is going to be a lot of work (all together it was 5 years of tinkering) but now I know what to do with my spare time during the christmas holidays.
Greetings Maarten
Edit:.
Even with a new setup it says: “system unhealty” after a while.
I don’t have a clou about what is wrong with my setup.
## System Information
version | core-2022.12.8
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.7
os_name | Linux
os_version | 5.15.76-v8
arch | aarch64
timezone | Europe/Amsterdam
config_dir | /config
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 9.4
update_channel | stable
supervisor_version | supervisor-2022.11.2
agent_version | 1.4.1
docker_version | 20.10.19
disk_total | 58.0 GB
disk_used | 2.4 GB
healthy | failed to load: Unhealthy
supported | true
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons |
</details>
<details><summary>Dashboards</summary>
dashboards | 1
resources | 0
mode | auto-gen
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 29 december 2022 om 19:10
current_recorder_run | 29 december 2022 om 20:10
estimated_db_size | 0.24 MiB
database_engine | sqlite
database_version | 3.38.5
