Addons installation without supervisor
Hello !
I’m using Home Assistant, supervised, using a virtual machine with the .qcow2 file provided on download page.
I want to move Home Assistant to docker, so it will be without supervisor.
How can I on a non supervised install use :
  • Schedy
  • File Editor
  • Mosquitto broker
Thanks :slight_smile:
Not an addon so supervisor irrelevant
sudo apt install editor of your choice
sudo apt install mosquitto
thanks @nickr !
For the file editor, it was about the addon in webinterface :
Ok for Schedy : just another container with AppDaemon and it should work. Same for mosquitto broker.
Containerise them if you like. Or not, as you prefer.
You can use any editor you like.
