Hi all, I was looking for Xiaomi gateway addon and couldn’t find it.
In add-on store I did have the community add-ons initially.
Firstly I tried adding the Xiaomi Gateway ( …home-assistant.io/integrations/xiaomi_aqara/ or …github.com/home-assistant/core/tree/dev/homeassistant/components/xiaomi_aqara ) repositories via the “Manage add-on repositories” and got the “Not a valid add-on repository”.
I did noticed the https://addons.community repository was present in the “Manage add-on repositories” window.
I tried different repositories links, including …addons.community/edge/ which should work, but same error.
Then, as a test, I deleted the https://addons.community repository from the “Manage add-on repositories” window and tried to re-add but I get the same error “Not a valid add-on repository”
Please note that before I removed the community repository, add-ons from it were installing OK, for example the Visual Studio code and SSH&Web Terminal (not the official Terminal&SSH) are working OK.
The install I have is in virtual box on intel hardware and the log shows as below:
20-10-18 19:54:54 INFO (MainThread) [supervisor.host.services] Update service information
20-10-18 19:54:55 INFO (MainThread) [supervisor.host.network] Update local network information
20-10-18 19:55:10 INFO (MainThread) [supervisor.store.git] Clone add-on https://addons.community repository
20-10-18 19:55:11 ERROR (MainThread) [supervisor.store.git] Can't clone https://addons.community repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://addons.community /data/addons/git/942cda15
stderr: 'Cloning into '/data/addons/git/942cda15'...
fatal: repository 'https://addons.community/' not found
/usr/src/supervisor/supervisor/store/git.py:89: RuntimeWarning: coroutine 'GitRepo._remove' was never awaited
self._remove()
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
20-10-18 19:55:11 ERROR (MainThread) [supervisor.store] Can't load from repository https://addons.community
20-10-18 19:55:11 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 0 new - 0 remove
I did search both forum and web about this but everybody seems to just enable the advanced mode and all good, but I did enable the Advanced Mode already and rebooted it a couple of times.
system info:
System Health
arch x86_64
chassis vm
dev false
docker true
docker_version 19.03.11
hassio true
host_os HassOS 4.14
installation_type Home Assistant OS
os_name Linux
os_version 5.4.69
python_version 3.8.5
supervisor 247
timezone Europe/London
version 0.116.4
virtualenv false
Lovelace
dashboards 1
mode auto-gen
resources 0
