Thanks! This worked…
Could you solve it to @eric1905? If so and the solution is in the thread feel free to mark it as solved so other users can find it easier
It worked for me as well. Thank you for the solution. Simple & Efficient !!!
I had also the same issue. All addons grayed out after SSD migration. Switched back to SD and all back to normal.
Then I saw this thread and thought to go through re-installing all addons.
However, to by big surprise, all were running just fine.
So…maybe proper restart fixed the issue?
Legend that worked - thank you!
Power on & off the Raspi 4 also solved the problem for me, too.
Thank you!
Me too - I had changed the Pi to boot from USB and restored a full backup from a clean HA install. Full reboot sorted it
