I’m running a supervised install on debian 10. As a pre-cursor to upgrading to debian 11, I decided to sort out my docker server installation. It worked OK but was still using dockerd from way back.
I stopped all the HA services and docker itself and then follwed the official guide to install docker on debian Install Docker Engine on Debian | Docker Documentation removing the old docker and installing docker-ce. I then used the script at https://github.com/home-assistant/supervised-installer to reinstall HA. After a reboot, HA started OK, but any addon reuiring network access failed to start.
Example is nginx_proxy
http+docker://localhost/v1.41/containers/c53cf2c6780580af03726a64e56cff79c965576ad1bd1cb186cd58600890f85e/start: Internal Server Error ("driver failed programming external connectivity on endpoint addon_core_nginx_proxy (41b8e30a39f50c9c01f0264bb741a69f843315edc4c8e70f749cba8d3fa45ee8): Error starting userland proxy: listen tcp [::]:443: bind: address already in use")
COMMENT: port 443 is not in use by any other process.
Similar messages appear for core-mosquitto
, appdaemon
etc. All are failing due to not being able to bind to the external address.
There’s nothing in the HA logs, supervisor
log is empty and journal
is not very informative unfortunately.
Oct 11 11:41:41 docker2 systemd[12002]: var-lib-docker-overlay2-8d42999d75b08746df5fe85b836b37158e1fe1e5c76bd8278f4a6d3b12a0f4af\x2dinit-merged.mount: Succeeded.
-- Subject: Unit succeeded
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The unit UNIT has successfully entered the 'dead' state.
Oct 11 11:41:41 docker2 systemd[12002]: var-lib-docker-overlay2-8d42999d75b08746df5fe85b836b37158e1fe1e5c76bd8278f4a6d3b12a0f4af-merged.mount: Succeeded.
This repeats every 30 secs.
