Addons not working after 0.57.1 update
I’m very very new to this…I was running hassio version 0.47 ish, and clicked on the update button in the config menu.
When hass restarted my addons won’t start. I have uninstalled the addons and reinstalled by they do not start.
SAMBA + other addon not working after upgrade…
Here is my log file if that helps…Thanks
The following errors have been logged this session:
2017-11-05 16:50:22 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key “sensor”. Check lines 61 and 87.
2017-11-05 16:50:22 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key “sensor”. Check lines 87 and 98.
2017-11-05 16:50:22 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key “group”. Check lines 75 and 107.
2017-11-05 16:50:25 ERROR (SyncWorker_1) [homeassistant.components.weather.bom] Could not get BOM weather station from lat/lon
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 216, in async_add_entity
yield from entity.async_device_update(warning=False)
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 309, in async_device_update
yield from self.hass.async_add_job(self.update)
File “/usr/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/camera/arlo.py”, line 163, in update
self.attrs[ATTR_BATTERY_LEVEL] = self._camera.get_battery_level
File “/usr/lib/python3.6/site-packages/pyarlo/camera.py”, line 135, in get_battery_level
return base.get_camera_battery_level[self.device_id]
TypeError: ‘NoneType’ object is not subscriptable
2017-11-05 16:50:47 ERROR (MainThread) [homeassistant.components.camera] Error on device update!
future.result()
2017-11-05 16:50:48 ERROR (MainThread) [homeassistant.components.camera] Error on device update!
future.result()
future.result()
2017-11-05 16:50:50 ERROR (MainThread) [homeassistant.components.camera] Error on device update!
future.result()
File “/usr/lib/python3.6/site-packages/homeassistant/components/camera/arlo.py”, line 164, in update
self.attrs[ATTR_BRIGHTNESS] = self._camera.get_battery_level
Maybe it’s a dumb question, but I have to ask: have you checked the lines in configuration.yaml?
Next, try to read the Release Notes for all the updates between 0.47 to 0.57 looking the “breaking changes” section, you can have a config that is not supported anymore for a syntax change.
Finally, post here the relevant lines from your config file (removing passwords and secrets, of course). Without them it’s impossible to give any advice.
Thanks. I reinstalled Docker and it fixed the problem.
