Hello
recently i moved my HA installation from my Raspberry Pi 4 to a VM on my unraid server.
I did so by importing a Backup file from the Raspberry installation.
A lot of the move worked really well, my Zigbee devices needed but they do work.
My installed Addons however do not work. non of them can start.
For a test i removed my “Advanced SSH & Web Terminal” addon and reinstalled it. but this did also not work.
after that i created a new VM without applying the backup file. To verify i installed a Addon - this did work.
Then i applied my backup file again, now the Addons do not start.
is this a known issue? is there somewhere a reference that links addons with my ARM based installation on the Raspberry?
is there a way to fix this, or will i need to re-do my setup on the VM?
thanks your your help.
