since a few days ago - I think with the current update, some of my addons do not work anymore (especially the standard file editor, or samba share). It will create these error logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service configurator: starting
s6-rc: info: service configurator successfully started
s6-rc: info: service legacy-services: starting
Error relocating /lib/libcrypto.so.3: unsupported relocation type 15
s6-rc: info: service legacy-services successfully started
[14:51:34] ERROR: Something went wrong contacting the API
jq: error (at <stdin>:1): Cannot iterate over null (null)
Python path configuration:
PYTHONHOME = (not set)
PYTHONPATH = (not set)
program name = '/usr/bin/python3'
isolated = 0
environment = 1
user site = 1
import site = 1
sys._base_executable = '/usr/bin/python3'
sys.base_prefix = '/usr'
sys.base_exec_prefix = '/usr'
sys.platlibdir = 'lib'
sys.executable = '/usr/bin/python3'
sys.prefix = '/usr'
sys.exec_prefix = '/usr'
sys.path = [
'/usr/lib/python310.zip',
'/usr/lib/python3.10',
'/usr/lib/python3.10/lib-dynload',
Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
Python runtime state: core initialized
File "/usr/lib/python3.10/encodings/__init__.py", line 31, in <module>
ValueError: source code string cannot contain null bytes
[14:51:34] INFO: Service exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service configurator: stopping
s6-rc: info: service configurator successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
I didn’t change anything - I don’t understand why it has not set the python variables anymore.
I’m running Home Assistant OS on a Raspberry Pi 4:
Home Assistant 2023.10.5
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0 - latest
Home Assistant OS on a Raspberry Pi 4 via SD Card
System was restarted several times (real restarts, not only restart of Home Assistant)
With OS I actually have no clue on how to update to/ get Python 3.11
Sorry, no idea then… it should automatically update with the OS I guess, but I’m using a different type of installation ( Core installation on a standard debian bookworm)
Install on SSD (Not SD), after install you could try with a restore, from a “working” backup ( then you still have your “half-working-SD-card-installation” to return back to )
PS: Backup files is basically .tar files, you can open them in most unzip/untar programs, and copy/paste, relevant parts/configs/files
I have the same issue on HASS OS since about 2 month now. Python packages from dependencies cannot be installed anymore.
Here an example for the waste_collection_schedule add on:
Unable to install package icalevents: Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/local/lib/python3.12/site-packages/pip/__main__.py", line 22, in <module> from pip._internal.cli.main import main as _main File "/usr/local/lib/python3.12/site-packages/pip/_internal/cli/main.py", line 10, in <module> from pip._internal.cli.autocompletion import autocomplete File "/usr/local/lib/python3.12/site-packages/pip/_internal/cli/autocompletion.py", line 10, in <module> from pip._internal.cli.main_parser import create_main_parser File "/usr/local/lib/python3.12/site-packages/pip/_internal/cli/main_parser.py", line 9, in <module> from pip._internal.build_env import get_runnable_pip File "/usr/local/lib/python3.12/site-packages/pip/_internal/build_env.py", line 15, in <module> from pip._vendor.packaging.requirements import Requirement SyntaxError: source code string cannot contain null bytes
This is plain HASS OS. It’s said to be the most stable but seems to have issues so far.
