Addon's option “Edit in yaml” not showing yaml config
Why is my HA addons yaml configuration not showing anymore?
Edit in UI works but “Edit in yaml”.Below are screen shots about it.
And in addition there are extra options for “SSH & Web Terminal” add-on (Audio input and output). This is very peculiar.
Could you please help me?
Samba is working and I can edit it with UI.
You don’t mention what version of HA you’re using or what browser, both of which would be helpful. I will say that if you are using Safari on recent versions of Mac OS, you need to update HA to at least 2023.4.0. There was a change in how Safari renders CSS that caused an issue with viewing YAML configs in the GUI that is fixed in HA 2023.4.0 and later.
Thank you very much! I ran now HA 2023.3.5 and yes, I use Safari (latest version).
I’ll install the latest HA version which seems now be 2023.4.2.
Now I have installed HA 2023.4.2.
With Safari yaml config for add-ons does not work at all.
I cleared cache and refresh page and still it’s not working with Safari.
With Firefox yaml configs work ok.
There is still something wrong with SSH&Web Terminal add-on.
When I try to edit yaml config, HA displays both UI & yaml config.
Below is screen capture (Firefox) in yaml config mode of SSH&Web Terminal add-on.
SSH&Web Terminal log is ok.
Anyway all seems to work ok.
