I took a full backup of HA running on RPi4 SD, flashed HA on an SSD, flased the USB boot script on another SD and got HA booting from SSD on my Argon M.2 without any SD.
Ip ist the same, logged in and restored the backup. Every Addon is not running and will not start.
I found this
Logger: aiohttp.server
Source: components/frontend/__init__.py:281
First occurred: 08:43:02 (1 occurrences)
Last logged: 08:43:02
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 67, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 234, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 146, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/hassio/addon_panel.py", line 61, in post
await _register_panel(self.hass, addon, data)
File "/usr/src/homeassistant/homeassistant/components/hassio/addon_panel.py", line 81, in _register_panel
await panel_custom.async_register_panel(
File "/usr/src/homeassistant/homeassistant/components/panel_custom/__init__.py", line 122, in async_register_panel
frontend.async_register_built_in_panel(
File "/usr/src/homeassistant/homeassistant/components/frontend/__init__.py", line 281, in async_register_built_in_panel
raise ValueError(f"Overwriting panel {panel.frontend_url_path}")
ValueError: Overwriting panel a0d7b954_ssh
