habb0
November 11, 2025, 6:23am
1
Versio core-2025.11.1
Host operating system
Debian GNU/Linux 13 (trixie)
Update channel
beta
Supervisor version
supervisor-2025.11.2
Just updated docker and then reboot. Now addons wont start at all.
Any nice trick?
Well…
Trick is but not are fix.
When system reboot, then:
ha supervisor reload
ha supervisor restart
If system reboot again, auto start still not working
thoompje
(Thoompje)
November 11, 2025, 8:56am
2
I have exactly the same problem after upgrading the following packages:
containerd.io (1.7.29-1)
docker-ce-cli (5:28.5.2-1)
docker-ce (5:28.5.2-1)
docker-ce-rootless-extras (5:28.5.2-1)
I will try downgrading later today one by one which one is causing this.
pipacsba
(Agoston Lorincz)
November 11, 2025, 12:12pm
3
I have the same issue, also after the docker update. The trick from @habb0 worked for now, thank you for that!
Tamsy
(Tamsy)
November 11, 2025, 12:44pm
4
habb0:
Any nice trick?
It seems like some changes coming with the latest containerd.io 2.1.5-1 is breaking the loading of Add-Ons.
If on HA Supervised and Debian 12 (bookworm) you can easily downgrade:
Go to the CLI.
As root user do:
systemctl stop docker
apt remove docker-ce docker-ce-cli containerd.io
apt install docker-ce=5:28.5.2-1~debian.12~bookworm docker-ce-cli=5:28.5.2-1~debian.12~bookworm containerd.io=1.7.29-1~debian.12~bookworm
Now switch to the normal (unpriviledged) user HA is running with and then do:
sudo -i
cd /usr/local/src
mv homeassistant-supervised.deb homeassistant-supervised.deb.orig
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
dpkg -i homeassistant-supervised.deb
Reboot the host.
If you want to put any further upgrades to docker on hold until the issue has been sorted out just do from CLI:
sudo apt-mark hold docker-ce docker-ce-cli containerd.io
To unhold:
sudo apt-mark unhold docker-ce docker-ce-cli containerd.io
As for Debian 13 (trixie) look up the the last version (before latest) to downgrade to that version:
sudo apt-cache policy docker-ce
sudo apt-cache policy docker-ce-cli
sudo apt-cache policy containerd.io
bosit
November 12, 2025, 11:49am
5
Thanks worked like a charm
pipacsba
(Agoston Lorincz)
November 15, 2025, 7:53am
6
For me issue persist with docker-ce 5:29, no need to upgrade yet.
Or you could try:
apt reinstall docker-ce=5:28.5.2-1~debian.12~bookworm docker-ce-cli=5:28.5.2-1~debian.12~bookworm containerd.io=1.7.29-1~debian.12~bookworm
Then you won’t have to reinstall homeassistant-supervised.deb. At least it worked for me.
pipacsba
(Agoston Lorincz)
November 21, 2025, 7:09am
8
With the following versions everything is went back to normal for me:
containerd.io:
Installed: 2.1.5-1~debian.13~trixie
docker-ce:
Installed: 5:29.0.2-1~debian.13~trixie
docker-ce-cli:
docker-ce-rootless-extras:
Tamsy
(Tamsy)
November 21, 2025, 8:07am
9
Thank you fort letting us know
The same goes for the latest docker versions for Debian 12 bookworm:
If put on hold before just initiate from CLI:
Then run a normal system upgrade:
sudo apt update && sudo apt upgrade && sudo apt autoremove
which will upgrade the outdated docker versions to the latest.
Reboot the host and all will be back to normal again
