I’ve been using Adguard quite happily for a few weeks - but today it stopped working, the errors in the log are like so:
20-05-31 12:36:59 ERROR (SyncWorker_15) [supervisor.docker] Can't create container from addon_a0d7b954_adguard: 404 Client Error: Not Found ("No such image: hassioaddons/adguard-armv7:2.4.1")
I uninstalled and reinstalled the addon and it works again now. I’m guessing that somehow it failed to pull the new version of the docker image - possibly because I was using adguard as DNS so it couldn’t resovle the docker host while it was down?
Is there a way to force honme assistant to re-pull images?
20-05-31 19:33:38 ERROR (SyncWorker_18) [supervisor.docker] Can’t create container from addon_a0d7b954_adguard: 404 Client Error: Not Found (“No such image: hassioaddons/adguard-armv7:2.4.1”)
Ok, it’s not a free space issue. I was thinking it might be a similar situation to updating HA and a 404 error indicated not enough free space. Guess that’s not the case here.
Same problem, I think it was the addon update I installed this morning (2.4.1).
Since I installed the addon recently and I didn’t change the settings that much I reinstalled it and it worked fine.
The issue has been reported here, with some possible fixes.
What worked for me was installing Terminal & SSH from the Add-on store. Then pasting and running ha supervisor repair in the terminal. I had to start and restart Adguard a couple of times before it started working again
I’m sorry but this addon has been running great for quite some time without me having to do any static IP configuration. I’m not sure if addon and manual changed to require this or I was just lucky, but you’re right that I hadn’t done that. So then I went through and created USB stick as instructed, which didn’t seem to do anything. Then I did it manually through nmcli verifying it had been done afterwards (nmcli> print ipv4) and yet I’m still not able to load AdGuard and still get
20-06-03 13:15:26 ERROR (SyncWorker_1) [supervisor.docker] Can't create container from addon_a0d7b954_adguard: 404 Client Error: Not Found ("No such image: hassioaddons/adguard-armv7:2.4.1")
in the system log. So forgive me for saying, but this isn’t really straightforward as it looks right now. I’d put myself in the somewhat seasoned tech user having worked in software tech industry for 20 years.
