Adguard fatal error
I’m trying to run addguard on my server. I installed the comunity addon but when i start the plugin i keep getting this message.
Im running hassio in docker on a NUC.
[18:53:20] INFO: Starting AdGuard Home server…
2020/02/06 18:53:20 [info] AdGuard Home, version v0.100.9, channel release
2020/02/06 18:53:20 [info] Upstream 0: https://dns.quad9.net:443/dns-query
2020/02/06 18:53:20 [info] Go to http://127.0.0.1:45158
2020/02/06 18:53:21 [info] Starting the DNS proxy server
2020/02/06 18:53:21 [info] Ratelimit is enabled and set to 20 rps
2020/02/06 18:53:21 [info] The server is configured to refuse ANY requests
2020/02/06 18:53:21 [info] DNS cache is enabled
2020/02/06 18:53:21 [info] Creating the UDP server socket
2020/02/06 18:53:21 [fatal] Couldn’t start forwarding DNS server, cause: couldn’t listen to UDP socket, cause: listen udp 0.0.0.0:53: bind: address already in use
Does anyone know how to solve this?
I have the same problem.
Creating the UDP server socket 2020/05/24 10:21:54 [fatal] Couldn’t start forwarding DNS server, cause: couldn’t listen to UDP socket, cause: listen udp 0.0.0.0:53: bind: address already in use
have you solved this guys?
