Adguard home - but not the addon - integration
Hi all,
I have decided to run 2 instances of adguard home separately from homeassistant. I have had a few times I was busy with home assistant and 1 memory leak lacking DNS services for my clients.
Now I have 2 instances spread of 2 physcial machines.
My question is how I can “add” those 2 integrations into home assistant…
For the addon (which I will delete later on) I now have:
And I have the according entities available in hom assistant.
But If I want to add another integration for adguard:
What Can I do?
It’s not possible currently (don’t know if it is planned). You can however use the adguard API and create your own sensor and switches. Take a look at this topic.
Seen that… thought so :see_no_evil:
