Adguard Home does not work
Hello I hope you can help me I am trying to install Adguard Home for the first time but when I give it to start I get this error in the registry.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: AdGuard Home
 Network-wide ads & trackers blocking DNS server
 Add-on version: 4.1.2
 You are running the latest version of this add-on.
 System: Home Assistant OS 5.13  (amd64 / qemux86-64)
 Home Assistant Core: 2021.5.4
 Home Assistant Supervisor: 2021.04.3
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] adguard.sh: executing...
/var/run/s6/etc/cont-init.d/adguard.sh: line 27: null: unbound variable
[cont-init.d] adguard.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Me to, but further symptoms. Adguard was installed and previously working. But DNS was “dropping out” and after checking the adguard logs, I could see it was continually restarting after an error about not being able to bind to a udp port? Uninstalled and re-installed. Not I get the same error.
Cheers.
PDJ
Hello, after doing what you told me it’s still the same :frowning:
Also have this problem
Was working before the latest update.
Could it be that just the day I want to install the addon itself fails?
Yes. Looks like the addon is broken. We need to wait for the smart one to find and fix the error.
Hi. It seems Franck Nijhof already fixed it in the repo. We just have to wait until it’s published to Hassio :slight_smile:
see Ensure compared variable is bound by frenck · Pull Request #180 · hassio-addons/addon-adguard-home · GitHub
It seems to be working but now it’s something I think I did wrong, I get this error.
[13:01:02] INFO: Starting AdGuard Home server...
2021/05/20 13:01:03.166063 [info] AdGuard Home, version v0.106.3
2021/05/20 13:01:03.166585 [info] home.upgradeSchema0to1(): called
2021/05/20 13:01:03.166624 [info] deleting /data/adguard/dnsfilter.txt as we don't need it anymore
2021/05/20 13:01:03.166682 [info] home.upgradeSchema1to2(): called
2021/05/20 13:01:03.166722 [info] deleting /data/adguard/Corefile as we don't need it anymore
2021/05/20 13:01:03.166762 [info] home.upgradeSchema2to3(): called
2021/05/20 13:01:03.166789 [info] home.upgradeSchema3to4(): called
2021/05/20 13:01:03.166810 [info] home.upgradeSchema4to5(): called
2021/05/20 13:01:03.166890 [info] home.upgradeSchema5to6(): called
2021/05/20 13:01:03.166919 [info] Upgrade yaml: 6 to 7
2021/05/20 13:01:03.166933 [info] Upgrade yaml: 7 to 8
2021/05/20 13:01:03.166958 [fatal] unexpected type of dns.bind_host: <nil>
After upgrading to 4.1.4 it’s working again for me, I did need to reboot host before I could install 4.1.4 however.
It’s the first time I install it so I’m not sure if it’s because I didn’t do something right with this:
In the end I did it through docker and it didn’t give me any problems.
Version 4.1.6 now available for install and the issues seem to be fixed.
