I’ve got a Docker server in which both HA and several other apps including Adguard are installed in containers. When I try to set up the Adguard integration it can’t connect to my Adguard instance, with the below error in my logs.
Basically, Traefik reverse proxies Adguard such that I can go to https://adguard.mydomain.com to interact with it. During setup the installer for Adguard changed itself to port 80 and my Traefik labels represent that. I can use Adguard itself just fine (53 is directly exposed for DNS). The domain is a real one with a valid LE SSL certificate and I have DNS entries set up in Adguard so that my clients point to the internal lan IP address.
I’m not sure what is happening. It could be trying to connect to port 3000 despite having a port field which might result in the 404 error. Any help is appreciated.
Config screen for the intergation:
Traefik log (included for thoroughness, from another attempt):
172.27.0.1 - - [30/May/2021:17:14:54 +0000] "GET /control/status HTTP/1.1" - - "-" "-" 86 "-" "-" 0ms
192.168.1.221 - - [30/May/2021:17:14:54 +0000] "POST /api/config/config_entries/flow/d73ab95d89a945b6a0ebb25797066d92 HTTP/2.0" 500 55 "-" "-" 85 "ha-secure@docker" "http://172.27.0.4:8123" 7ms
Home Assistant log:
Logger: aiohttp.server
Source: components/adguard/config_flow.py:93
First occurred: 12:35:13 AM (36 occurrences)
Last logged: 2:27:09 AM
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 74, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 131, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 155, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 63, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 109, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 199, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 257, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/adguard/config_flow.py", line 93, in async_step_user
await adguard.version()
File "/usr/local/lib/python3.8/site-packages/adguardhome/adguardhome.py", line 223, in version
response = await self.request("status")
File "/usr/local/lib/python3.8/site-packages/adguardhome/adguardhome.py", line 164, in request
raise AdGuardHomeError(
adguardhome.exceptions.AdGuardHomeError: (404, {'message': '404 page not found\n'})
