I suspect the root cause was the change of network interface names in HAOS11 breaking what AdGuard was bound to. That would explain why some folk reported just pressing SAVE fixed things - AdGuard found the new eth0 device name.
If you’re using AdGuard for blocking, the DHCP server needs to pass out the AdGuard IPv4 for DNS (likely the HASS IP), and the router IPv4 for default router (same as before - router IP).
The traffic routes the same, it’s just AdGuard selectively modifying DNS to block crap like Samsung wanting to know what TV you’re watching at all times.
TTFN,
Under IPV4 settings what do you have in the “Gateway address” and “DNS server” fields?
I can’t remember if we are supposed to put router IP (192.168.1.1) for both of those or just “Gateway address” and if the “DNS” field was supposed to include a traditional DNS (e.g. 1.1.1.1) or the IP of the raspberry pi that is running the home assistant software and adguard IP.
All of those settings were wiped out with the OS upgrade
Yes, I just need to force “save” the config (by toggle back and forth the ssl option) . That triggers a restart of the AdGuard Addon. Upon restart, it starts (re)listening to the machine IP address (in additional to the 172.30.32.1 address
