I have the strange problem, that Adguard works perfectly fine on my Pixel 5, however on an older LG V30 and my Win11 Laptop there is no sign of blocked ads in sight. Neither blocked services are working. I don’t even have a clue why the Pixel is working and the rest is not nor what to look for to fix it. Can anyone help me out?
Thx in advance
Are all your devices using the same DNS server? Are you using DHCP or fixed ip addresses? If you filter the adguard logs. do you see the ip addresses of the devices where adguard doesn’t work?
As far as I can see, yes:
I’m using the DHCP settings on my router and the local dns server is set to my raspi ip address:
If you mean in the clients tab, yes I can see every device and they supposedly all have blocked content
If you mean the add-on log files, I can’t see any other IP Addresses, but I can find the error message “buffer site too small”. Might this have anything to do with the issue?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: AdGuard Home
Network-wide ads & trackers blocking DNS server
Add-on version: 4.5.1
You are running the latest version of this add-on.
System: Home Assistant OS 8.0 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.5.5
Home Assistant Supervisor: 2022.05.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] adguard.sh: executing...
[cont-init.d] adguard.sh: exited 0.
[cont-init.d] discovery.sh: executing...
[02:34:51] INFO: Successfully send discovery information to Home Assistant.
[cont-init.d] discovery.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[02:34:55] INFO: Starting AdGuard Home server...
2022/05/20 02:34:55.877377 [info] AdGuard Home, version v0.107.6
2022/05/20 02:34:55.938694 [info] Initializing auth module: /data/adguard/data/sessions.db
2022/05/20 02:34:55.941938 [info] auth: initialized. users:0 sessions:0
2022/05/20 02:34:55.942710 [info] Initialize web module
2022/05/20 02:34:56.184671 [info] AdGuard Home is available at the following addresses:
2022/05/20 02:34:56.184731 [info] Go to http://127.0.0.1:45158
[02:34:56] INFO: Starting NGinx...
2022/05/20 02:34:58.749592 [info] Starting the DNS proxy server
2022/05/20 02:34:58.749636 [info] Ratelimit is enabled and set to 25 rps
2022/05/20 02:34:58.749650 [info] The server is configured to refuse ANY requests
2022/05/20 02:34:58.749663 [info] DNS cache is enabled
2022/05/20 02:34:58.751614 [info] MaxGoroutines is set to 300
2022/05/20 02:34:58.752473 [info] Creating the UDP server socket
2022/05/20 02:34:58.753195 [info] Listening to udp://192.168.0.3:53
2022/05/20 02:34:58.753227 [info] Creating the UDP server socket
2022/05/20 02:34:58.754122 [info] Listening to udp://172.30.32.1:53
2022/05/20 02:34:58.754152 [info] Creating a TCP server socket
2022/05/20 02:34:58.754903 [info] Listening to tcp://192.168.0.3:53
2022/05/20 02:34:58.754935 [info] Creating a TCP server socket
2022/05/20 02:34:58.755817 [info] Listening to tcp://172.30.32.1:53
2022/05/20 02:34:58.756518 [info] Entering the UDP listener loop on 192.168.0.3:53
2022/05/20 02:34:58.757631 [info] Entering the tcp listener loop on 192.168.0.3:53
2022/05/20 02:34:58.757669 [info] Entering the tcp listener loop on 172.30.32.1:53
2022/05/20 02:34:58.757643 [info] Entering the UDP listener loop on 172.30.32.1:53
2022/05/20 02:40:01.435019 [error] unpacking udp packet: dns: buffer size too small
2022/05/20 02:40:04.441826 [error] unpacking udp packet: dns: buffer size too small
2022/05/20 03:45:17.593009 [error] unpacking udp packet: dns: buffer size too small
2022/05/20 03:45:20.617365 [error] unpacking udp packet: dns: buffer size too small
2022/05/20 04:19:20.584235 [error] unpacking udp packet: dns: buffer size too small
2022/05/20 04:19:23.490758 [error] unpacking udp packet: dns: buffer size too small
2022/05/20 08:10:36.291224 [error] unpacking udp packet: dns: buffer size too small
2022/05/20 08:10:39.305810 [error] unpacking udp packet: dns: buffer size too small
