AdGuard with google WIFI
I have just installed AdGuard on my system. To cover my entire network, I have changed the DNS on my Google wifi to point to the AdGuard server.
The issue is that Google wifi is distributing the gateway IP adress to the clients, and not the new DNS IP adress. Google do use the new DNS adress, but the “Top Clients” list only shows the Google GW (192.168.86.1).
Is there a fix for this, or do I need to set static DNS on each client ?
What I want to do is that I get the clients IP (or name) in the “Top Clients” list, and not the GW…
I am interested in a solution here too.
I have the same issue as well. I do have few devices with static IP but still shows the default address and not specific client.
I have the same issue and it looks like the issue is that DHCP can’t be entirely disabled on Google Wifi without a Static IP from your ISP or PPPoE. There seem to be some workaround, such as https://www.reddit.com/r/GoogleWiFi/comments/a9qi0c/pihole_with_google_wifi/ecoqglt/ or https://discourse.pi-hole.net/t/how-do-i-configure-my-devices-to-use-pi-hole-as-their-dns-server/245. Both examples reference pi-hole but it should work the same for the AdGuard Home addon, just need to enable the DHCP server.
