Oh yes, the issue was tbe youtube link wasn’t working. I’ve changed them and the Adhan and surahs are playing NORMALLY now. Still don’t know how to get it playing according to Malaysia timezone.
Hmm, I’m playing it locally, but still can’t get it to play anything at all.
Hello guys. The above guide is now a kind of redundant as the method of playing azan is now available as integration rather than sensors. I am trying to install hassio but due to some weird reason installation is failing continuously. I will update this guide once I get around this.
How do you display the “time” for each Namaz … Mine is showing “In X hours” by default.
Maybe try sharing your code? How are you playing it locally? I uploaded the mp3 to google drive and use the link from there, works just fine…
The only thing is the timing… Offset at set manually s if the original timing changes then my offset will be minutes off.
Some asked abt the offset… It should be in seconds… So if you need to start it 5 minutes before the timing, put - 360…
If you look at my configuration.yaml file above there is a template being created for each prayer.
When you go to add an entity on your dashboard you have to select the friendly names Salah Fajr, Salah Dhuhur etc to show the times. Let me know if its still unclear and I will try to send screenshtos.
Hi @msahar, everything was working for a long time - also I had got some help from you in the past. But since updating to 0.109.6 yesterday I do not get any sensors detected. Is it what you referring to? I was playing some locally stored Adhan and some prayers with offset. What changes will I need to make in my files to get things back again? Here are my file outputs. Really need it working. I miss Adhan at the time of breaking fast. Thank you in advance.
configuration.yaml
homeassistant:
customize: !include customize.yaml
latitude: xxxxx
longitude: xxxxx
unit_system: metric
time_zone: Asia/Hong_Kong
default_config:
discovery:
media_extractor:
# Sensors
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'time_date'
- platform: islamic_prayer_times
calculation_method: karachi
sensors:
- fajr
- dhuhr
- asr
- maghrib
- isha
- midnight
# Dark Sky Weather
- platform: darksky
api_key: !secret darksky_api
monitored_conditions:
- temperature
- cloud_cover
- humidity
- pressure
- temperature_high
- temperature_low
# Asus router
asuswrt:
host: 192.168.1.1
username:
port:
ssh_key: /config/ssh/openssh2
telegram_bot:
- platform: polling
api_key: !secret Telegram_Api
allowed_chat_ids:
- !secret Telegram_Chat_Id
notify:
- name:
platform: telegram
chat_id: !secret Telegram_Chat_Id
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
automation.yaml
# Automation for Azan
- action:
- alias: 'Azan'
entity_id: media_player.living_room_speaker
media_content_id: http://192.168.1.10:8123/local/azans/azan2.mp3
media_content_type: audio/mp3
service: media_extractor.play_media
- data:
volume_level: '0.55'
service: media_player.volume_set
alias: Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_dhuhr"), "%Y-%m-%dT%H:%M:%S")) +240 }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S")) +2700 }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S")) +120 }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_isha"), "%Y-%m-%dT%H:%M:%S")) +60 }}'
- action:
- alias: 'Fajar Azan'
media_content_id: http://192.168.1.10:8123/local/azans/fajarazan.mp3
- data:
volume_level: '0.25'
alias: Fajar Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) -60 }}'
automations.yaml
- id: 'idhere'
alias: 'Adhan'
description: Play Adhan on Google Home
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.fajr_prayer"), "%Y-%m-%dT%H:%M:%S"))
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.dhuhr_prayer"), "%Y-%m-%dT%H:%M:%S"))
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.asr_prayer"), "%Y-%m-%dT%H:%M:%S"))
%Y-%m-%d")) == as_timestamp(strptime(states("sensor.isha_prayer"), "%Y-%m-%dT%H:%M:%S"))
condition: []
- data:
entity_id: media_player.speaker_1
media_content_id: https://url.com/local/audio/azan1.mp3
- data:
volume_level: '0.8'
time_date.yaml
# Time and Date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'time_utc'
- 'beat'
- 'date_time_iso'
The Prayer Times is integrated using the HA Integrations, so there’s nothing in the configuration.yaml file.
Only
# Prayer Times
calculation_method: mwl
Please have a look the op, I have updated it thanks
I guess there is some problem with this url. Are you sure that you are able to access azan1.mp3 at this url?
The url works fine, I’ve just blanked it out for privacy reasons.
Please use this automation file.
# Automation for 5 times Azan
- action:
- alias: 'Azan'
media_content_id: https://www.islamcan.com/audio/adhan/azan2.mp3
- data:
volume_level: '0.9'
alias: Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.fajr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.dhuhr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.asr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.maghrib_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.isha_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
Hi @msahar any suggestion or idea please as why the timings displayed are UK GMT? I provided details above. Thank you.
Thanks, I have used the code you have attached, with some adjustments as there was some formatting errors, however I get the same issue. Nothing is being executed.
Also, what is the differences between this, and the method here?
Salaams Brother-
I am using a sonos wifi speaker- instead of a google speaker-
I have set up google assistant- followed all instructions-
I can’t see the Hassio.io - but used editor add on instead.
Everything has worked - but cannot trigger adhaan.
please help
Please share your configuration.yaml and automation.yaml files.
I age done exactly as you stated.
I feel the only problem is that I don’t own a google speaker, I have so is speakers.
I have been able to connect my li to home assistant and able to send a message to Sonos through HA, cannot run code - please help …
Have followed all instructions- except that I don’t have a google mini, instead using google assistant with sonos wifi speaker… please help
I can’t seem to see how I can send you a private message, if you could kindly message me privately so I can respond and send more images.
Thank you for you help brother, sorry to be trouble
Had the same issue this is what you need to use for SONOS
- alias: ‘Azan’
entity_id: media_player.family_room
media_content_id: https://www.islamcan.com/audio/adhan/azan1.mp3
media_content_type: music
service: media_extractor.play_media - data:
volume_level: ‘0.3’
alias: Adhan
