Thanks, i’ve added it. Everything works perfectly but i want the real time to show in the box rather than “hours ago”
The solution is somewhere up in the comments.
@msahar Sahar - I am having issue getting the sensors working. I am using raspbian and configured hass a virtual service thats configured to restart upon reboot. I cant find the islamic_Prayer_times sensor entities either. I am unsure what I am doing wrong. I can run the azan manually by clickin execute on the automation page. Can I mail you directly? My email firozozman @ gmail.com.
Thank you so much for your help.
Massalama
Salaam, all.
First off, thanks @msahar for setting this up, excellent directions, JZK. A few notes I thought I would share from my setup experience, which are tweaks of post #1 which you need as a framework.
Automation File Allowing for Individual Azhan Settings and Suhoor Alarm
The below automation.yaml file allows for individual settings (ie, individual azhan for Fajr which is different, etc), and using the Entity Card (below), you can turn off each azhan as needed.
It also adds a “Suhoor” alarm to wake up everyone in time during Ramadan.
Note, it uses local azhan mp3 files (great source here for many azhan options).
# Automation for 5 separate times Azan and Suhoor time alarm
# Separate alarm for Suhoor time wakeup
- action:
- alias: ''
entity_id: media_player.q_whole_home
media_content_id: http://192.168.1.204:8123/local/adhan_qetami.mp3
media_content_type: audio/mp3
service: media_extractor.play_media
- data:
volume_level: '0.3'
service: media_player.volume_set
alias: Suhoor
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) - 1800 }}'
# Separate alarm for Fajr Azan
- action:
- alias: ''
media_content_id: http://192.168.1.204:8123/local/adhan_Fajr_efasy.mp3
- data:
volume_level: '0.15'
alias: Adhan Fajr
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) }}'
# Zhuhr Alarm
- action:
- alias: ''
media_content_id: http://192.168.1.204:8123/local/adhan_makkah_short.mp3
- data:
volume_level: '0.3'
alias: Adhan Zhuhr
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_dhuhr"), "%Y-%m-%dT%H:%M:%S")) }}'
# Asr Alarm
- action:
- alias: ''
media_content_id: http://192.168.1.204:8123/local/adhan_makkah2.mp3
- data:
volume_level: '0.3'
alias: Adhan Asr
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S")) }}'
# Maghrib Alarm
- action:
- alias: ''
- data:
volume_level: '0.3'
alias: Adhan Maghrib
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S")) }}'
# Isha Alarm
- action:
- alias: ''
- data:
volume_level: '0.3'
alias: Adhan Isha
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_isha"), "%Y-%m-%dT%H:%M:%S")) }}'
Entity Card
The following Entity Card for the overview screen works well to give on/off for each alarm, and formats the prayer times to show the actual times.
entities:
- entity: automation.suhoor
- entity: automation.adhan_fajr
- entity: automation.adhan_zhuhr
- entity: automation.adhan_asr
- entity: automation.adhan_maghrib
- entity: automation.adhan_isha
- entity: sensor.islamic_prayer_time_fajr
format: time
- entity: sensor.islamic_prayer_time_sunrise
format: time
- entity: sensor.islamic_prayer_time_dhuhr
format: time
- entity: sensor.islamic_prayer_time_asr
format: time
- entity: sensor.islamic_prayer_time_maghrib
format: time
- entity: sensor.islamic_prayer_time_isha
format: time
title: Prayer Alarms
type: entities
Virtualbox on Windows PC
Finally, I use a Windows PC as I have one running full time anyway. You can run Home Assistant using Virtualbox as follows.
- Make sure your PC is 64 bit, and virtualization is turned on in your BIOS
- Download Virtualbox from Oracle (free) and install
- Download the VMDK file instead when you follow post #1 above
- In Virtualbox, choose “New” and then specify “Linux 2,3, 4 64 bit”
- Then, you still have to change 2 settings, open settings and turn on “UEFI boot” under system and then also change the network type to “Bridged adapter” (the later allows your HASS to access the internet connection)
- Run!
Few Other Notes
To put everything in one place, as I know others have mentioned, but “configurator” doesn’t seem to be an add-on any more, instead use “file editor”.
Thanks again to @msahar for setting this all up, Ramadan Mubarak!
Thanks for sharing your experience and taking time to help others.
thanks for sharing these tweaks! the athan link is a superb resource, and the entity card is a neat idea!
Salam Sahar,
JazakAllah Khair for the solution. I’m completely new to Pi & HASSIO and i’ve just landed my hands on one just today for this purpose. I have a Googgle Nest Hub and i’d like to use it for the
- Azaan five times
- End of Suhur notification
Problems i face
I’ve used OSX to flash my SD Card with HSSIO which doesn’t let me create the Wifi folder. So I can only connect with ethernet whch is not preferential
After having installed the scripts (attached below). I can only see the Adhan and toggle for other times is missing.
Salam,
I am trying to follow the installation guide and am unable to see the islamic prayer time states. I have restarted home assisstant, pi and reinstalled from scratch as well. Please help
Just as a follow up the automation also didn’t work and the Adhan didn’t play at Fajr.
Dear Msahar,
First of all thank you for your hard work and really its a great initiative
Everything was working fine till yesterday i got this message in the logs.
Log Details (ERROR)
Logger: homeassistant.components.sensor
Source: helpers/entity_platform.py:112
Integration: Sensor (documentation, issues)
First occurred: 3:05:41 PM (1 occurrences)
Last logged: 3:05:41 PM
The islamic_prayer_times platform for the sensor integration does not support platform setup. Please remove it from your config.
Please find below my config file and automation file
Config file
homeassistant:
latitude: 23.424076
longitude: 53.847818000000004
elevation: 154
unit_system: metric
time_zone: Asia/Dubai
default_config:
discovery:
media_extractor:
sun:
- platform: yr
- platform: time_date
display_options:- ‘time’
- ‘date’
- ‘date_time’
- ‘date_time_iso’
- ‘time_date’
- ‘time_utc’
- ‘beat’
- platform: islamic_prayer_times
calculation_method: makkah
sensors:- fajr
- dhuhr
- asr
- maghrib
- isha
Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
Automation file
Automation for 5 times Azan
- action:
- alias: ‘’
entity_id: media_player.living_room_speaker
media_content_id: https://www.islamcan.com/audio/adhan/azan2.mp3
#media_content_type: audio/youtube
service: media_extractor.play_media - data:
volume_level: ‘0.9’
alias: Adhan
condition: []
trigger:- platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_fajr”), “%Y-%m-%dT%H:%M:%S”)) }}’ - platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_dhuhr”), “%Y-%m-%dT%H:%M:%S”)) }}’ - platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_asr”), “%Y-%m-%dT%H:%M:%S”)) }}’ - platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_maghrib”), “%Y-%m-%dT%H:%M:%S”)) }}’ - platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_isha”), “%Y-%m-%dT%H:%M:%S”)) }}’
- alias: ‘’
So i figured out the islamic prayer times is now available as an integration.
then in your configuration.yaml remove
sensors:
* fajr
* dhuhr
* asr
* maghrib
* isha
Following which in your automations.yaml rename the islamic prayer sensors
islamic_prayer_time_fajr = fajr_prayer
islamic_prayer_time_dhuhr = dhuhr_prayer
islamic_prayer_time_asr = asr_prayer
islamic_prayer_time_maghrib = maghrib_prayer
islamic_prayer_time_isha = isha_prayer
Can you please share the complete automation file with the new configuration you mentioned above. Thanks.
Below are the configuration files. You have to modify the configuration.yaml for your location information.
You may have to modfy the automation.yaml for your prayer time calculation method.
After updating the configurations restart the server and create your entity cards as needed to show the time & automation controls.
This is what i have on my dashboard.
Automations.yaml
# Automation for Sehri Dua
- action:
- alias: 'Sehri Dua'
entity_id: media_player.adhan_group
media_content_id: https://www.thesufi.com/Islamic-Collection/Islamic_Audio_Section/67-Islamic-Masnoon-Dua-Arabic-with-Urdu-Translation-MP3/Dua-and-Supplications--22-.mp3
- data:
volume_level: '0.6'
alias: Sehri_Dua
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.fajr_prayer"), "%Y-%m-%dT%H:%M:%S"))-35 }}'
# Automation for Iftari Dua
- action:
- alias: 'Aftari Dua'
media_content_id: https://www.thesufi.com/Islamic-Collection/Islamic_Audio_Section/67-Islamic-Masnoon-Dua-Arabic-with-Urdu-Translation-MP3/Dua-and-Supplications--23-.mp3
- data:
volume_level: '0.6'
alias: Aftari_Dua
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.maghrib_prayer"), "%Y-%m-%dT%H:%M:%S"))-45 }}'
# Automation for Fajr Azan
- action:
- alias: 'FajrAzan'
media_content_id: https://archive.org/details/MakkahFajrAdhan6913SheikhAliMullah
- data:
volume_level: '0.6'
alias: Fajr_Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.fajr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
# Automation for 4 times Azan
- action:
- alias: 'Azan'
media_content_id: http://praytimes.org/audio/adhan/Sunni/Adhan%20Makkah.mp3
- data:
volume_level: '0.8'
alias: Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.dhuhr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.asr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.maghrib_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.isha_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
### Restart HA to force update Islamic Time Sensors at 1AM ###
- alias: Restart HA
platform: time
at: "01:00:00"
- service: homeassistant.restart
Configuration.yaml
homeassistant:
latitude: YOUR_LAT
longitude: YOUR_LONG
elevation: YOUR_ELEVATION
unit_system: metric
time_zone: YOUR_TZ
default_config:
discovery:
media_extractor:
# Example configuration.yaml using a non-default calculation method
islamic_prayer_times:
calculation_method: isna
# Sensors
display_options:
- 'time'
- 'date'
- 'time_date'
sensors:
salah_fajr:
friendly_name: "Salah Fajr"
value_template: >
{%- set a = states("sensor.fajr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.fajr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_dhuhr:
friendly_name: "Salah Dhuhr"
value_template: >
{%- set a = states("sensor.dhuhr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.dhuhr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_asr:
friendly_name: "Salah Asr"
value_template: >
{%- set a = states("sensor.asr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.asr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_maghrib:
friendly_name: "Salah Maghrib"
value_template: >
{%- set a = states("sensor.maghrib_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.maghrib_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_isha:
friendly_name: "Salah Isha"
value_template: >
{%- set a = states("sensor.isha_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.isha_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
# Text to speech
tts:
Hello all, i am trying my code out. everything was working and recently has stopped working. I cant still get the 4 prayers to play but the Farj and Morning quls and night quls, not playing. It only makes a beep sound and thats it. Would be great if anyone can help look into my code. Thanks in advance. Also how do i make my timing to follow malaysia? currently i’ve added a few minutes but it changes each day depending on the world’s islamic timing… so i have to change manually each time.
- action:
- alias: 'Azan'
entity_id: media_player.living_speaker
media_content_id: https://www.youtube.com/watch?v=IYww573mn9U
- data:
volume_level: '0.9'
alias: Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_dhuhr"), "%Y-%m-%dT%H:%M:%S")) +180}}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S")) +60}}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S")) +120}}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_isha"), "%Y-%m-%dT%H:%M:%S")) +360}}'
- action:
- alias: 'Azan farj'
media_content_id: https://www.youtube.com/watch?v=VHcRTIcRvN
- data:
volume_level: '0.5'
alias: Adhan Farj
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) +60}}'
- alias: Restart HA
platform: time
at: "01:00:00"
# Automation for Morning Quls
- action:
- alias: 'Morning Quls'
media_content_id: https://www.youtube.com/watch?v=Zap5DPPgZJM
- data:
volume_level: '0.7'
alias: Morning Quls
platform: time
at: "08:30:00"
# Automation for Night Quls
- action:
- alias: 'Night Quls'
- data:
volume_level: '0.9'
alias: Night Quls
platform: time
at: "22:45:00"
Could you please show me your config and automation scripts
Thanks for sharing. Perfect timing… worked well for me
Amazing effort.
This is my Salah dashboard.
Assalamu Alikum
I have read all above instruction and then i have one question.
I want to Adjust Azar Prayer Offset 30 Minutes .how can i do it .
(i found for 5 minutes - +3600) i didnt get this calculation
Can you please explain for me
Have you found the fix? Same Issue here.
