Thanks for your immediate replay .
I will wait up to 2 days and after that confirm with you the status .
If not working after 2 days I believe you will help me to fix
If anyone want to offset the prayer times by several minutes, you can use a single Template Trigger like this:
- alias: 'Example 1'
value_template: >
{% set f = as_timestamp(states('sensor.fajr_prayer')) + 300 %}
{% set d = as_timestamp(states('sensor.dhuhr_prayer')) + 300 %}
{% set a = as_timestamp(states('sensor.asr_prayer')) + 300 %}
{% set i = as_timestamp(states('sensor.isha_prayer')) + 300 %}
{% set m = as_timestamp(states('sensor.maghrib_prayer')) + 300 %}
{{ now().timestamp() | int in [f, d, a, i, m] }}
... etc ...
It offsets each of the five prayer times by 5 minutes (300 seconds). Each prayer time’s offset can, of course, be set to whatever you want. The example adds the offset to the prayer time but, if needed, you can change it so it subtracts the offset from the time,
If you want the ability to adjust the offset time in the Lovelace UI, I suggest creating five input_number
entities, one for each prayer time. The following example shows how to configure five input_numbers where each one permits setting a value between 0 and 20 minutes.
Click to reveal configuration example for input_numbers
input_number:
fajr:
min: 00
max: 20
step: 1
dhuhr:
min: 00
max: 20
step: 1
asr:
min: 00
max: 20
step: 1
isha:
min: 00
max: 20
step: 1
Maghrib:
min: 00
max: 20
step: 1
Then you can use the following Template Trigger:
- alias: 'Example 2'
value_template: >
{% set f = as_timestamp(states('sensor.fajr_prayer')) + states('input_number.fajr')|int * 60 %}
{% set d = as_timestamp(states('sensor.dhuhr_prayer')) + states('input_number.dhuhr')|int * 60 %}
{% set a = as_timestamp(states('sensor.asr_prayer')) + states('input_number.asr')|int * 60 %}
{% set i = as_timestamp(states('sensor.isha_prayer')) + states('input_number.isha')|int * 60 %}
{% set m = as_timestamp(states('sensor.maghrib_prayer')) + states('input_number.maghrib')|int * 60 %}
... etc ...
Dear aamans .
From today night it has started working for me .I didn’t do anything.
But there is one issue only .the Isha prayer time is different with Qatar actual prayer time .
Actual Isha Time 7:29 PM
BUT showing in home assistant 7:58 PM
Kindly helpe to fix the issue .
Other everything is good
@shamseer change the calculation method to one that gives the right time.
Google aladhan prayer api and read through the different methods. Change the code in config.yaml to define sensors. HTH
As salam,
I would like to know will this also work with Amazon Alexa Echo Dot?
@fshaikh15 I have made it work is Echo that’s what I am using now, it’s a bit more involved as you need to install HACS and Alexa media player. see my post on the Hanafi Islamic prayer topic here
hi, my salah times are showing UTC values. sensor.salah_fajr is UTC but sensor.fajr_prayer is correct. how can i solve this?
for some reason now my Dhuhr Prayer Athan is not triggering, everything else is. It’s not even giving an error in the log file
anyone having the same problem
Please help, Automated adhan not working for me. No adhan has happened. I used your code.
Hi Team,
I am new to Home Assistant and following the code above but to no avail. Can someone please help on the below code:
Configuration.Yaml:
homeassistant:
latitude: -35.282001
longitude: 149.128998
elevation: 577
unit_system: metric
time_zone: Australia/Sydney
#default_config:
discovery:
media_extractor:
#sun:
#- platform: weather_data
- platform: time_date
display_options:- ‘time’
- ‘date’
- ‘date_time’
- ‘date_time_iso’
- ‘time_date’
- ‘time_utc’
- ‘beat’
#- platform: islamic_prayer_times
calculation_method: makkah
#sensors:
# - fajr
#- dhuhr
# - asr
#- maghrib
#- isha
sensors:
salah_fajr:
friendly_name: “Salah Fajr”
value_template: >
{%- set a = states(“sensor.fajr_prayer”).split(“T”)[1].split(":")[0] -%}
{%- set b = states(“sensor.fajr_prayer”).split(“T”)[1].split(":")[1] -%}
{{ a + “:” + b }}
salah_dhuhr:
friendly_name: “Salah Dhuhr”
value_template: >
{%- set a = states(“sensor.dhuhr_prayer”).split(“T”)[1].split(":")[0] -%}
{%- set b = states(“sensor.dhuhr_prayer”).split(“T”)[1].split(":")[1] -%}
{{ a + “:” + b }}
salah_asr:
friendly_name: “Salah Asr”
value_template: >
{%- set a = states(“sensor.asr_prayer”).split(“T”)[1].split(":")[0] -%}
{%- set b = states(“sensor.asr_prayer”).split(“T”)[1].split(":")[1] -%}
{{ a + “:” + b }}
salah_maghrib:
friendly_name: “Salah Maghrib”
value_template: >
{%- set a = states(“sensor.maghrib_prayer”).split(“T”)[1].split(":")[0] -%}
{%- set b = states(“sensor.maghrib_prayer”).split(“T”)[1].split(":")[1] -%}
{{ a + “:” + b }}
salah_isha:
friendly_name: “Salah Isha”
value_template: >
{%- set a = states(“sensor.isha_prayer”).split(“T”)[1].split(":")[0] -%}
{%- set b = states(“sensor.isha_prayer”).split(“T”)[1].split(":")[1] -%}
{{ a + “:” + b }}
automation.yaml:
Automation for 4 times Azan
- action:
- alias: ‘Azan’
entity_id: media_player.family_room_speaker
media_content_id: Azan masjid e nabvi madina munawra|| beautiful voice 2021|| Azan | madina - YouTube
media_content_type: video/youtube
service: media_extractor.play_media - data:
volume_level: ‘0.9’
service: media_player.volume_set
alias: Adhan
condition: []
trigger:- platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_dhuhr = dhuhr_prayer”), “%Y-%m-%dT%H:%M:%S”)) }}’ - platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_asr = asr_prayer”), “%Y-%m-%dT%H:%M:%S”)) }}’ - platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_maghrib = maghrib_prayer”), “%Y-%m-%dT%H:%M:%S”)) }}’ - platform: template
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_isha = isha_prayer”), “%Y-%m-%dT%H:%M:%S”)) }}’
- alias: ‘Azan’
Separate alarm for Fajar Azan
- action:
- alias: ‘FajrAzan’
media_content_id: Azan e Fajar Live | Madina Live | 2021 | Masjid e Nabawi - YouTube
volume_level: ‘0.8’
alias: Fajr_Adhan
condition: []
value_template: ‘{{ as_timestamp(strptime(states(“sensor.time_date”), “%H:%M, %Y-%m-%d”)) == as_timestamp(strptime(states(“sensor.islamic_prayer_time_fajr = fajr_prayer”), “%Y-%m-%dT%H:%M:%S”)) }}’
- alias: ‘FajrAzan’
Restart HA to force update Islamic Time Sensors at 1AM
- alias: Restart HA
platform: time
at: “01:00:00”
action:- service: homeassistant.restart
Even if i execute it manually, Azan is not played either on minor Google Nest Hub. Your help will be really appreciated please.
Even the prayer times are not correct based on the Australia/Sydney Timezone.
Alright Alhumdulilah I sorted out. All good.
Usman brother computers love to work is zulu time aka UTC/GMT. so if you convert this time to your local time it will be a correct time.
Asalamu Alaykum,
I was having the same issue (manually triggering works but automatic doesn’t work), so I copied this code but it is still not working, please advise.
JazakAllahu Khairan
alrighty, Alhumdulillah I fixed it. The sensor entity id was wrong in my “Actions” area.
Hi guys, followed the instructions but Adhan times are note accurate… I set time zone and gps coordination accordingly… changed the calculation method to isna
I should have times below as of Jun 27th…
05:00
13:02
17:12
20:54
22:14
Hi, anyone could help, I am trying to setup this for the mosque… I set time zone and gps coordination accordingly… changed the calculation method to isna but prayers times are incorrect
Time display as UTC. someone figured out how to convert to local times?
Assalm u alikum, I hope someone can help me. I am trying to setup the automation script so that it mutes my Samsung soundbar before playing the Adhan on the google home mini (for Duhur, Asr, Magrib and Isha).
I am very new to all this.
# Automation for 5 times Azan
# Automation for Zuhur, Asr, Magrib, and Isha
- action:
service: media_player.volume_mute
- data:
entity_id: media_player.home_theater_speaker
is_volume_muted: true
- alias: 'Azan'
entity_id: media_player.living_room_speaker
media_content_id: https://www.islamcan.com/audio/adhan/azan1.mp3
media_content_type: audio/mp3
- data:
volume_level: '0.6'
#Turning on the input boolean to trigger the Google Homes to start playing the Adhan
entity_id: input_boolean.Adhan
#The delay is based on how long the actual Adhan audio is, for this Adhan, it is just around 2 minutes and 14 seconds
- delay: '00:02:14'
alias: Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.dhuhr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.asr_prayer"), "%Y-%m-%dT%H:%M:%S")) +2400 }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.maghrib_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.isha_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
- service: media_player.volume_mute
is_volume_muted: false
#Seperate Automation for Fajr
- action:
- alias: 'Azan'
media_content_id: https://download.tvquran.com/download/TvQuran.com__Athan/TvQuran.com__01.athan.mp3
- data:
volume_level: '0.4'
alias: Fajr_Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.fajr_prayer"), "%Y-%m-%dT%H:%M:%S")) }}'
### Restart HA to force update Islamic Time Sensors at 1AM ###
- alias: Restart HA
platform: time
at: "01:00:00"
I am getting the following parse error.
YAMLException: end of the stream or a document separator is expected at line 4, column 1:
Could some one please help.
Jazzakallah
Update
I am based in Sydney Australia.
Hardware: Using VM through Virtualbox and following the instructions on
Windows - Home Assistant. -
Windows PC is always running
Integrated Google Home Mini successfully.
Followed the instructions (installing file editor, updating configuration.yaml and automation.yaml as advised in this article)
Configuration.yaml
homeassistant:
latitude: -33.907028
longitude: 151.022690
unit_system: metric
default_config:
discovery:
media_extractor:
sun:
# Islamic prayer times integration
islamic_prayer_times:
calculation_method: karachi
# Sensors
display_options:
- 'time'
- 'date'
- 'time_date'
sensors:
salah_fajr:
friendly_name: "Salah Fajr"
value_template: >
{%- set a = states("sensor.fajr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.fajr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_dhuhr:
friendly_name: "Salah Dhuhr"
value_template: >
{%- set a = states("sensor.dhuhr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.dhuhr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_asr:
friendly_name: "Salah Asr"
value_template: >
{%- set a = states("sensor.asr_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.asr_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_maghrib:
friendly_name: "Salah Maghrib"
value_template: >
{%- set a = states("sensor.maghrib_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.maghrib_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
salah_isha:
friendly_name: "Salah Isha"
value_template: >
{%- set a = states("sensor.isha_prayer").split("T")[1].split(":")[0] -%}
{%- set b = states("sensor.isha_prayer").split("T")[1].split(":")[1] -%}
{{ a + ":" + b }}
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
automations.yaml
# Automation for 4 times Azan
- action:
- alias: ''
entity_id: media_player.dining_room_speaker
media_content_id: https://www.islamcan.com/audio/adhan/azan2.mp3
- data:
volume_level: '0.4'
alias: Adhan
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_dhuhr"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S")) }}'
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_isha"), "%Y-%m-%dT%H:%M:%S")) }}'
# Separate alarm for Fajar Azan
- action:
- alias: ''
entity_id: media_player.dining_room_speakerr
media_content_id: https://www.islamcan.com/audio/adhan/azan3.mp3
- data:
volume_level: '0.4'
alias: Adhan
condition: []
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) }}'
- alias: Restart HA
platform: time
at: "02:00:00"
Results / Outcome
- Automations does not work, as per the states in developer tool, the did not trigger, snip is attached. One Observation is that the name of YAML file for automation in HA is named as automations.yaml
snip of entities states in developer tools
- Dashboard widget looks like this, although the timings of Adhan are not as per my timezone. Please advise how can I show the Adhan timings as per my timezone?
Looking forward hearing from you.
JazzahAllah
Salam @msahar , really appreciate your effort in setting adhan automation. I have been following the thread and found myself bit lost after an integration of Islamic Prayer Time was introduced in Home Assistant.
Is it possible to have specific instructions to configure and automate with Islamic Prayer Time. You probably have already done that but wanted to segregate it from current topic.
JazzakAllah.
Mohsin
