Adhan Automation (الأذان التلقائي للصلاة) using google speaker
One Error I was able to find was the naming of entity (entity_id: media_player.**dining_room_speakerr**) was wrong for Fajr prayers resulting not in playing this. I will wait for Dhuhur prayers to see if it works and update the thread.
JazzakAllah
Update:
Alhamdulillah, I was able to play Asr Adhan … There was change in sensor naming convention in automation that caused the issue, I have corrected it as it was advised in the comments. Following is the correct automations.yaml file
automations.yaml
- id: '1517693010922'
  alias: Adhan
    value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M,
      %Y-%m-%d")) == as_timestamp(strptime(states("sensor.dhuhr_prayer"), "%Y-%m-%dT%H:%M:%S"))
      %Y-%m-%d")) == as_timestamp(strptime(states("sensor.asr_prayer"), "%Y-%m-%dT%H:%M:%S"))
      %Y-%m-%d")) == as_timestamp(strptime(states("sensor.maghrib_prayer"), "%Y-%m-%dT%H:%M:%S"))
      %Y-%m-%d")) == as_timestamp(strptime(states("sensor.isha_prayer"), "%Y-%m-%dT%H:%M:%S"))
  condition: []
  - alias: ''
      entity_id: media_player.dining_room_speaker
      media_content_id: https://www.islamcan.com/audio/adhan/azan2.mp3
      media_content_type: audio/mp3
    service: media_extractor.play_media
  - data:
      volume_level: 0.4
    service: media_player.volume_set
  mode: single
- id: '1517693034922'
  alias: Fajar Azaan
      %Y-%m-%d")) == as_timestamp(strptime(states("sensor.fajr_prayer"), "%Y-%m-%dT%H:%M:%S"))
  condition: []
  - alias: Fajar
      media_content_id: https://www.islamcan.com/audio/adhan/azan3.mp3
  - data:
      volume_level: 0.4
      area_id: living_room
      device_id: 83982c1f80fda986dd93cfbee8f335d7
  mode: single
- alias: Restart HA
    platform: time
    at: 02:00:00
  - service: homeassistant.restart
JazzakAllah
The information presented in the first post of this thread is almost 3 years old. Some of it is outdated and there are now simpler, easier ways to do the same things.
For example, I posted a revised version of the automation here and it demonstrates that the original Template Triggers can be replaced with a far more compact Time Trigger:
  - platform: time
    at:
    - sensor.fajr_prayer
    - sensor.dhuhr_prayer
    - sensor.asr_prayer
    - sensor.maghrib_prayer
    - sensor.isha_prayer
If we apply this enhancement to your two automations, we get this:
  alias: Adhan
  - platform: time
    at:
    - sensor.asr_prayer
  condition: []
  - service: media_extractor.play_media
  - service: media_player.volume_set
      volume_level: 0.4
  mode: single
  alias: Fajar Azaan
  - platform: time
    at: sensor.fajr_prayer
  condition: []
      volume_level: 0.4
  mode: single
In addition, the Islamic Prayer integration can now be configured via the UI:
Therefore it is no longer necessary to configure it via configuration.yaml
# This is not needed because it can now be done via the UI
islamic_prayer_times:
    calculation_method: karachi
The optional five Template Sensors, showing the current day’s prayer times, can be reduced to this:
    sensors:
      salah_fajr:
        friendly_name: "Salah Fajr"
        value_template: "{{ states('sensor.fajr_prayer') | as_timestamp | timestamp_custom('%H:%M') }}"
      salah_dhuhr:
        friendly_name: "Salah Dhuhr"
        value_template: "{{ states('sensor.dhuhr_prayer') | as_timestamp | timestamp_custom('%H:%M') }}"
      salah_asr:
        friendly_name: "Salah Asr"
        value_template: "{{ states('sensor.asr_prayer') | as_timestamp | timestamp_custom('%H:%M') }}"
      salah_maghrib:
        friendly_name: "Salah Maghrib"
        value_template: "{{ states('sensor.maghrib_prayer') | as_timestamp | timestamp_custom('%H:%M') }}"
      salah_isha:
        friendly_name: "Salah Isha"
        value_template: "{{ states('sensor.isha_prayer') | as_timestamp | timestamp_custom('%H:%M') }}"
Thank you a lot for the updated information! I was wondering if it was possible to only show the highlighted information instead of all of that data:
@123
Could you please help me out configuring the configuration.yaml? I’m using the version you posted above. I now get this error:
2021-12-06 01:05:20 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'as_timestamp' got invalid input 'unknown' when rendering template '{{ states('sensor.fajr_prayer') | as_timestamp | timestamp_custom('%H:%M') }}' but no default was specified. Currently 'as_timestamp' will return 'None', however this template will fail to render in Home Assistant core 2022.1
Any help is very welcome! Thank you!
It’s not an error, it’s a warning.
The message clearly explains why:
‘as_timestamp’ got invalid input ‘unknown’
The result of this:
was unknown.
That means the value of sensor.fajr_prayer is unknown. Did you install the Islamic Prayer Times integration? Do you see five sensors in Configuration > Entities related to the Prayer Times integration?
Thank you a lot! That was indeed the problem: I did not have the Islamic Prayer Times installed. Thanks again!
Guys, the times which is gives to me is not really correct, some of 10 minutes after or before. How can i setup some + or - to let me see the correct times on lovelace?
pryaer
type: glance
entities:
  - entity: sensor.fajr_prayer
    format: time
  - entity: sensor.dhuhr_prayer
    format: time
  - entity: sensor.asr_prayer
    format: time
  - entity: sensor.maghrib_prayer
    format: time
  - entity: sensor.isha_prayer
    format: time
Same problem did you just find the problem? See my question up maybe a workaround if that is possible to let see the lovelace the time with some +10 min -10 min as example.
Can someone post an updated version of this, I cannot get this working correctly. the original post is outdated as of today and does not function correctly.
Currently, I am getting the following error in the logs, It does execute when I run the automation manually but does not execute on its own or on the correct time.
Thank you
Scroll up about 7 posts and you’ll find an updated version posted on July 29. That post also contains a link to the following simplified version:
https://community.home-assistant.io/t/adhan-automation-using-home-assistant-and-google-home-mini/135622/290?u=123
Still not working below is the error
That’s not one of the simplified versions I suggested.
@123
Thank you, after I reapplied the automation using your simplified version, everything worked as expected.
Below is my configuration for anyone who wishes to use it.
Configuration.yaml
homeassistant:
  latitude: xxxx
  longitude: xxxxx
  elevation: xx
  unit_system: metric
  time_zone: Asia/Kolkata
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
discovery:
media_extractor:
sun:
updater:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
  discovery: true
  discovery_prefix: homeassistant
  broker: 192.168.xxx.xxx
  port: 18xx
  client_id: xxxxxxx
  keepalive: 60
  username: xxxxxxxxx
  password:xxxxxxxxxx
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - xxx
  - platform: time_date
    display_options:
      - "time"
      - "date"
      - "date_time"
      - "date_time_iso"
      - "time_date"
      - "time_utc"
      - "beat"
Automations.yaml
- id: "1517693010922"
  alias: Adhan
    - platform: time
      at:
        - sensor.asr_prayer
  condition: []
        entity_id: media_player.living_room_speaker
        volume_level: 1.0
  mode: single
Sensors.yaml
sensors:
  salah_fajr:
  salah_dhuhr:
  salah_asr:
  salah_maghrib:
  salah_isha:
Glad to hear it works for you but why did you feel the need to re-post the example that I had already posted?
This thread is already exceedingly long and filled with duplications; it’s preferable to just link to a post.
Because you don’t have everything in a single place, plus it’s not user-friendly because you don’t mention what goes in which file. If I had to guess these things from your post, I am sure others who are new would also have to guess the same, therefore I mentioned the complete information in 1 single post instead of going back and forth to different posts.
@Himdola and others looking for Diyanet times:
I’ve managed to make this work using scrape. Go to the diyanet website and change the location based on your current location. My example below is set to Rotterdam, The Netherlands: Diyanet İşleri Başkanlığı | Rotterdam İçin Namaz Vakti
You should change the URL in below and copy paste this in your configuration.yaml
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
  - platform: scrape
    resource: https://namazvakitleri.diyanet.gov.tr/tr-TR/13980/rotterdam-icin-namaz-vakti
    select: "#today-pray-times-row > div:nth-child(1) > div > div.tpt-time"
  - platform: scrape
    select: "#today-pray-times-row > div:nth-child(2) > div > div.tpt-time"
  - platform: scrape
    select: "#today-pray-times-row > div:nth-child(3) > div > div.tpt-time"
  - platform: scrape
    select: "#today-pray-times-row > div:nth-child(4) > div > div.tpt-time"
  - platform: scrape
    select: "#today-pray-times-row > div:nth-child(5) > div > div.tpt-time"
  - platform: scrape
    select: "#today-pray-times-row > div:nth-child(6) > div > div.tpt-time"
    sensors:
     imsak_vakti:
      friendly_name: "İmsak Vakti"
      value_template: "{{ states('sensor.imsak') == states('sensor.time') }}"
    sensors:
     gunes_vakti:
      friendly_name: "Güneş Vakti"
      value_template: "{{ states('sensor.gunes') == states('sensor.time') }}"
    sensors:
     ogle_namazi:
      friendly_name: "Öğle Vakti"
      value_template: "{{ states('sensor.ogle') == states('sensor.time') }}"
    sensors:
     ikindi_namazi:
      friendly_name: "İkindi Vakti"
      value_template: "{{ states('sensor.ikindi') == states('sensor.time') }}"
    sensors:
     aksam_namazi:
      friendly_name: "Akşam Vakti"
      value_template: "{{ states('sensor.aksam') == states('sensor.time') }}"
    sensors:
     yatsi_namazi:
      friendly_name: "Yatsı Vakti"
      value_template: "{{ states('sensor.yatsi') == states('sensor.time') }}"
Go to your automations.yaml and add this:
- alias: Namaz
  - platform: state
    entity_id:
    - sensor.imsak_vakti
    - sensor.ogle_namazi
    - sensor.ikindi_namazi
    - sensor.aksam_namazi
    - sensor.yatsi_namazi
    to: "True"
  - service: media_player.play_media
      entity_id: media_player.home_group
      media_content_id: https://www.naataudio.com/downloads/IslamicRingtones/bismillah_ir_rahman.mp3
      media_content_type: music
      volume_level: '0.2'
Lovelace would look like this:
type: glance
entities:
  - entity: sensor.imsak
    icon: mdi:clock-time-five-outline
  - entity: sensor.ogle
  - entity: sensor.ikindi
  - entity: sensor.aksam
  - entity: sensor.yatsi
state_color: false
show_state: true
show_icon: true
show_name: true
columns: 5
It’s this kind of attitude that makes me regret having providing assistance in this topic.
Given that my contributions have been so terribly difficult to comprehend, I have decided to cease participation to avoid confusing anyone else.
From now on, you can answer any questions about my examples you have re-posted. Good luck.
@123 Just ignore that guy. I found your contribution very valuable! Thanks.
Thank you so many many much. It is so simple and working like a charm, i was looking so long time a long as 2 years a solution to get that information from diyanet site. But my developer skills are so bad. Thank you thank you…
