Adjust color of state icon
I despair of adjusting the color of a “state icon” in a “picture_elements” map.
type: picture-elements
elements:
  - type: state-icon
    entity: input_boolean.VIS_Mobbie_Fehlermeldung_Basis_bool
    icon: mdi:garage
    tap_action:
      action: navigate
      navigation_path: /lovelace/roborock_reset
    style:
      top: 4%
      left: 5%
      '--mdc-icon-size': 30px
      '--paper-item-icon-color': white
      '--paper-item-icon-active-color': red
This is what it currently looks like. Lines 13 and 14 have no effect.
Where did I get the error?
the two CSS variables you need to overwrite are --state-input_boolean-on-color and --state-input_boolean-off-color, so your example would look like this:
elements:
  - type: state-icon
    icon: mdi:garage
    tap_action:
      action: navigate
    style:
      top: 4%
      left: 5%
      '--state-input_boolean-off-color': white
      '--state-input_boolean-on-color': red
This’ll work for an input_boolean, other types of entities will require slight adjustments to set e.g. --state-light-on-color.
You can find which variables to set by opening your browser’s devtools then activating the “select” mode (Ctrl+Shift+C in Chrome or Firefox), and clicking on the icon in your picture elements card.
The inspector view will jump to the the HTML code of the icon (probably called ha-svg-icon), then look for its parent called ha-state-icon, marked red here:
That HTML element should have an inline style attribute defining a value for color, composed of a set of CSS variables, if you set one of them it’ll use that value instead of the default colors.
Hope this helps!
Thank you very much, everything matches the color now. Hopefully next time I’ll find out for myself using your method. Thank you
