Adjust theme for different views
I have different views on my lovelace dashboard and recently found the stunning ios-dark-mode theme which is aesthetically nice looking - important for me as the dashboard sits on a wall mounted tablet.
However I have views where I use the picture glance card and the rounded corners don’t really work there - see attached.
Theme for views
So I’m wondering whether it’s possible to apply different themes to different views. What I’d be considering is to create a clone of the ios-dark-theme with straight corner images which is then applied to corresponding views.
Not the end of the world if it can’t be done but I’m a stickler when it comes to presentation :smile:
Thank you! Works perfectly. I continue to be impressed just how customisable Home Assistant is :slight_smile:
No problem. If you mark my post as the solution it may help others searching for the same question.
I’d love to but some reason the rock box doesn’t appear
Even if you click on the three dots below the post?
Yep, I have seen it before in other posts but not this one. When I click the 3 dots this is what I get
Huh. Weird. The forum software was updated recently. Something must have changed. No idea what though.
Could it be because there’s only a picture and no text? Or maybe the ‘share your projects’ category is not meant to find solutions?
That would be it. I just changed the category and the solution button popped up.
Great. Got it and marked accordingly. Txs again!
