Adjustable minutes timer to turn on a switch?
Is there a lovelace card to add a timer where you have a) a slider or b) a scrollable time input field to start a manual timer that then turns on a switch and auto turns off after time has run out?
Background: I sometimes need the pool pump to run for a certain time to remove debris from the surface or after i added chemicals. But sometime forget to turn of the pump. So adding a configurable timer that turns the pump off for me would be great, and quite useable in other situations as well.
Hopefully this PR gets merged in the near future.
Yes! That looks good. Something like that, as well as a slider type if you want to enable something RIGHT NOW, and need it to turn off automatically after a given time.
I use input_number to do something similar to this:
You then are able to get the input number to minutes, then use an automation to compare the input_number to time then switch has been on for, in minutes
