Hello guys,
I am sorry in case this has been discussed here already, but I have not a suitable solution anywhere here or elsewhere.
I have Shelly 3EM monitoring my 3 phases in Ground Floor Flat.
Then I have couple of Fibaro Smartplugs, Shelly PMs etc…
When I configure my energy dashboard to add individual devices I would like to add all independent devices, such as PM minis, smarplugs… and then for the “untracked energy” use the diff between 3EM and the individual items, as if I would just add everything, the individually monitored devices will be counted twice, once on its own and then as a part of 3EM measurements.
therefore I thought I would create custom sensor as below
# Totals adjusted
energy_ground_floor_total_adjusted:
unique_id: energy_ground_floor_total_adjusted
friendly_name: Energy Ground Floor Total Adjusted
icon_template: mdi:flash
value_template: >-
{% set ground_floor = states('sensor.shellypro3em_2cbcbba5bc6c_total_active_energy')|float %}
{% set living_room_lamp = states('sensor.living_room_living_room_lamp_174_energy')|float %}
{% set office_lamp = states('sensor.office_office_lamp_172_energy')|float %}
{{ (ground_floor - living_room_lamp - office_lamp) }}
unit_of_measurement: "kWh"
I have also created custom sensor for 3EM only - purely for compartment
energy_ground_floor_total:
value_template: >-
{{ (states('sensor.shellypro3em_2cbcbba5bc6c_total_active_energy')|float) }}
and 2 utility meters
energy_daily_ground_floor_total:
source: sensor.energy_ground_floor_total
cycle: daily
unique_id: energy_daily_ground_floor_total
name: Energy Daily Ground Floor Total
energy_daily_ground_floor_total_template_adjusted:
source: sensor.energy_ground_floor_total_adjusted
cycle: daily
unique_id: energy_daily_ground_floor_total_template_adjusted
name: Energy Daily Ground Floor Total Adjusted
when I look at the individual sensors
and
the adjusted correctly showing the total value lowered by the sum value of individual devices
however, both utility meters showing the same value, and that is the value of the non-adjusted sensor.
any chance you could help me out, or point me the right direction what I might be doing wrong here?
Thanks in advance.
J
