I’ve been trying to set up a card so that I can adjust the channel volumes on my receiver using the helper input sliders. I’m stuck at trying to send a command to the receiver I’m not quite sure of the proper syntax. Here’s what I am trying to do.
two things I believe are missing…not calling ‘states’ of the sensor and the no-space with CVC
EDIT: or maybe not the space… code pages show a space too
Thanks for the help! I almost got it working. The problem now is that it’s not sending the input as an intager. My receiver is will not recognize 50.0 as a value. Just need to send the value as an integer. Thank you so much.
I’ve been pulling my hair out trying to get this to work.
The Denon App allows me to adjust the channel levels, so I assume I should be able to do it in HA.
I’m pretty novice and know very little about automations or how to add a new card to Lovelace for a custom automation.
Would you mind pasting your code entered in Automations and any other steps I need to take to get a card with the same sliders to adjust channel volume.
