I currently have an automation that adjusts my thermostat based on the outside temp, and it lowers the temp by 7 degrees once the conditions are met. I’ve found that it’s a bit too aggressive. I have found a much better setup that I want, but I’m just drawing blanks on how to proceed. I think I’m needing an IF statement or multiple automations, I would prefer an IF statement, so I only have to manage one automation. I don’t know how to make them, so that’s not helping me.
What I’m wanting to do for the conditions are that when the outside temp reaches a temp within range of 75-80 then set the thermostat to 75, if not in sleep or away modes. I also haven’t been able to figure how to setup the range as a condition. I am wanting the conditions to be:
Outside Temperature Range
Thermostat Cool Setting
< 74
Resume Program
75 - 80
75
81 - 85
76
86 - 90
77
91 - 95
78
> 96
79
I’m using an Ecobee thermostat and I’m also using the outside weather from the Ecobee.
Can anybody assist with either making an IF statement or a single automation that can accommodate this? I will post what I’ve tried to create in a reply below.
Hey man did you ever solve the issues with the automation. I too would like to setup my automation to run a similar sequence of based on forecast temperatures.
Unfortunately I have not. I don’t quite understand the programming language needed for the template. I know the logic will most likely be an IF Else statement, but I’m lost on what to do next.
