Adressable RGB Lights (Tuya) does not appear to work
So first of all I got to say that I’m pretty new to Home Assistant and this forum, so if I am in the wrong place i am very sorry for that.
I recently bought a LED Strip from LSC Smart Connect (action) and it seems that it does appear in Tuya IoT but not my Home assistant instance. Automatic link is enabled on the Tuya IoT platform and it does work in the Tuya app
Then we go over to home assistant and it seems like it doesn’t want to appear there.
The LED Strip has different zones to assign colors to (which might confuse homeassistant?) it also has 2 led strips connected to one module (2x 50cm) which is how it is designed to work.
Do you have any idea of what could possibly be wrong?
Sorry for my english grammar as it’s not one of my strong points.
I’m just about to buy exactly the same LED strips you’re talking about so I’m interested in the answer as well.
Or maybe you figure it out meantime?
I just bought it. Work with Tuya integration without any problems but there are limitations.
You can change colour and temperature of the light and control brightness. What you can’t do is to control individual sections or enable custom modes. This can only be done via Tuya app.
