There is many ways to do this: in device manager, xml file, in twincat - routes, using cerhost and TcAmsRemoteMgr. Last time I connected without any issues, today after many attemps I reinstalled HA and it is ok.
Are you using hassio? Mine crashes. And i guess HA should pop up when you do a broadcast search in twincat? I tried to add in the xml file but without success
Error during setup of component ads
File “/usr/local/lib/python3.6/site-packages/homeassistant/setup.py”, line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/ads/ init .py”, line 57, in setup
import pyads
File “/usr/local/lib/python3.6/site-packages/pyads/ init .py”, line 5, in
from .ads import open_port, close_port, get_local_address, read_state,
File “/usr/local/lib/python3.6/site-packages/pyads/ads.py”, line 23, in
from .pyads_ex import (
File “/usr/local/lib/python3.6/site-packages/pyads/pyads_ex.py”, line 46, in
_adsDLL = ctypes.CDLL(adslib)
File “/usr/local/lib/python3.6/ctypes/ init .py”, line 348, in init
self._handle = _dlopen(self._name, mode)
OSError: Error loading shared library /usr/local/lib/python3.6/site-packages/pyads/adslib.so: Exec format error
Hello. I am using home assistant on synology using docker.
I don’t see HA in broadcast search. I added staric route to HA.
In my case problem was that I didn’t select “Use same network as Docker Host”
Your config looks ok, I am not using Ip_address option.
Same problem here.
I’ve added a static route in the Beckhoff PLC, and added the ads: config to the configuration file.
Do I need to install something on Home Assistant?
As I look into the logs i receive the following error: 019-01-12 00:57:43 ERROR (MainThread) [homeassistant.setup] Error during setup of component ads
