when adding the ads component i got the next error:
OSError: Error loading shared library /usr/lib/python3.6/site-packages/pyads/adslib.so: Exec format error
Does any one have an idea
I have the same problem when adding the ads-component.
I use Hass.io on a raspberry Pi 3.
Anybody an idea what the problem is?
I have no errors but also still no values.
I made an ams route from the TwinCat2 PLC to the PI, but still no result.
How can i test the ads connection ?
how did you get rid of the above error? I still have the error from your first post here…
Yes, with hasbian I got it linked without error. But I don’t get how to define the light correctly. In my TwinCat there is a LightSample with the boolean WebOn and i have a variable for my living room light called .LivingRoomLight
How do I define that correctly? It should use the ADS variable .LivingRoomLight to set the boolean WebOn if i want to set the light on…
The ads communication is working with TwinCAT 2 and with TwinCAT 3.
I am using TwinCat2
Hi guys,
Also trying to use the ADS component on HassIO. Should this work?
My first attempts with the ADS component were on a windows system with Twincat installed on it. This was succesfull. All functions I tested worked immediately.
No with the HassIo on a raspberry pi it doesn’t seem to work.
Any suggestions?
