ADT Pulse integration
Yes. In the configuration.yaml.
I got the sensors and everything to work. the time i reported it not working was when the plugin was installed on a ubuntu vm. But moved my config to pi and connected. Now i just gotta figure out how to change the report to Open/Closed instead of devStatOk or open
thanks. Iā€™ll need the page before this one. I donā€™t know how the camera picture link is formed.
Here is the main dashboard
Hi All - I have this system! Excited to hear there is a way to work with it in Hass.io.
Iā€™m trying to get things up and running and I canā€™t figure this out.
What exactly goes in this section, in both username and password sections? Iā€™ve tried entering my local Mosquitto server creds,but it fails - I think?
> [email protected] start /usr/src/app
> node server.js
2018-7-24 16:48:16 Pulse.pulse Spanning
2018-7-24 16:48:16 Pulse: New Client undefined
2018-7-24 16:48:16 Pulse: Login called Authenticating
MQTT Sub to: home/alarm/cmd
2018-7-24 16:48:16 Pulse: Authentication Failed
2018-7-24 16:48:16 Pulse: httpResponse:[object Object]
2018-7-24 16:48:21 Pulse: Login called Authenticating
2018-7-24 16:48:21 Pulse: Authentication Failed
2018-7-24 16:48:21 Pulse: httpResponse:[object Object]
2018-7-24 16:48:26 Pulse: Login called Authenticating
Here is the config
  "ssl": false,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "pulse_login": {
    "username": "",
    "password": ""
  "mqtt_host": "10.1.30.194",
  "mqtt_connect_options": {
    "username": "",
    "password": ""
  "alarm_state_topic": "home/alarm/state",
  "alarm_command_topic": "home/alarm/cmd",
  "zone_state_topic": "adt/zone",
  "smartthings_topic": "smartthings",
  "smartthings": false
Thank you!
this needs to contain your ADT Pulse login for the portal.adtpulse.com.
@Ben_Ellis
thank you! I see how the image url is placed here.
To pull the image you need to be logged in to the pulse portal. I think itā€™s best to download the image and store it in HomeAssistant to display it inside the UI.
Iā€™ve added it to my todo list.
thanks.
@haruny
Ah! Got it!
How about the other section? Should that be where you enter the MQTT username and password?
Edit: disregard - all working nowā€¦ I think :slight_smile:
Tested when I got home. The alarm_away still doesnt set
No problem I will play also. Another thing to note. Arlo does the same thing. Pulls the image and stores it. I also think ring door bell does the same thing
I got it all working using MQTT - which is great. I can integrate this into Node-Red and do all kinds of cool automation - AWESOME! Thank you @haruny! Iā€™m going to share this great addon on reddit, with other folks who were hoping to find a way to integrate this ADT system type with their HA systems.
The only thing I canā€™t figrue out is how to make sensors from my sensors (doors/windows/etc) and then how to have them show up on the default dashboard?
I tried adding some bits of the text above and in the howto and I keep receving errors.
I have this in my configuration.yaml
alarm_control_panel:
  - platform: mqtt
    state_topic: "home/alarm/state"
    command_topic: "home/alarm/cmd"
    payload_arm_home: "arm_home"
    payload_arm_away: "arm_away"
    payload_disarm: "disarm"
But where in Hass.io can I use this?
I tried adding the sensors, but they give me configuration errors, whether I put the in configuration.yaml or binary_sensor.yaml
  - platform: mqtt
    state_topic: ā€œadt/zone/Garage Door/stateā€
    payload_on: ā€œOpenā€
    payload_off: ā€œOKā€
    retain: true
    value_template: ā€˜{{ value_json.status }}ā€™
Thanks for all the help!
Configure them as binary sensors following the example below. Replace YOUR_SENSOR_NAME with the exact name that ADT Pulse has associated with that zone/sensor. Change the device_class as appropriate for each zone/sensor.
Per @harunyā€™s instructions in an earlier post, you can get a dump of the zone/sensor data including names:
After running the add-on, to list all the zones found, you can call:
# mosquitto_sub -h YOUR_MQTT_IP -v -t "adt/zone/#"
Follow this example
- platform: mqtt
      name: "Z1 Entry Doors"
      device_class: door
      state_topic: "adt/zone/YOUR_SENSOR_NAME/state"
      payload_on: "devStatOpen"
      payload_off: "devStatOK"
      value_template: '{{ value_json.status }}'
Then just add the calls the binary_sensor in your dashboard.
Interesting - everything starts up fine and Iā€™m subā€™ed to the topic, but nothing prints out.
I can issue MQTT commands to arm/disarm/etc - but I donā€™t get a listing on that topic when starting the addon.
Any ideas?
Where do I place this? Everywhere I try I get an error.
In configuration.yaml under the heading for binary_sensor.
binary_sensor:
  - platform: mqtt
        device_class: door
Or if you break out your binary_sensor section to its own yaml file (like below), then youā€™d just place it in the binary_sensor.yaml.
binary_sensor: !include binary_sensor.yaml
Are you calling the command quoted above? Itā€™s a command line command. So you need to SSH to your Hass.io instance and execute the command. The addon doesnā€™t print out the listing. Thatā€™s totally separate.
Yep! I know how to use MQTT and Iā€™m typing the command within the console.
Similar to subscribing to home/alarm/cmd and I can see all my commands when I issue them.
I try to add this to binary_sensor.yaml, but then I receive an error on config check
Configuration invalid
Error loading /config/configuration.yaml: mapping values are not allowed here
  in "/config/binary_sensor.yaml", line 93, column 13
Here is the config.
  - platform: mqtt
        device_class: door
        state_topic: "adt/zone/Garage Door/state"
Sorry, that wasnā€™t clear from your question. I donā€™t know what to tell you. This is what I run and my results.
ha@hassio:~$ mosquitto_sub -h [MY_IP_ADDR] -v -u hass -P [PASSWORD] -t "adt/zone/#"
adt/zone/Z1 Entry Doors/state {"id":"sensor-9","devIndex":"E1VER1","name":"Z1 Entry Doors","tags":"sensor,doorWindow","status":"devStatOK","statusTxt":"Z1 Entry Doors - Closed\nLast Activity: Today 8:55 PM","activityTs":1531702508134}
adt/zone/Z2 Master Bedroom/state {"id":"sensor-10","devIndex":"E2VER1","name":"Z2 Master Bedroom","tags":"sensor,doorWindow","status":"devStatOK","statusTxt":"Z2 Master Bedroom - Closed\nLast Activity: 6/17 12:49 PM","activityTs":1529254141541}
adt/zone/Z3 Front Windows/state {"id":"sensor-11","devIndex":"E3VER1","name":"Z3 Front Windows","tags":"sensor,doorWindow","status":"devStatOK","statusTxt":"Z3 Front Windows - Closed\nLast Activity: 1/22 5:45 PM","activityTs":1516661127558}
adt/zone/Z4 Bedroom Windows/state {"id":"sensor-12","devIndex":"E4VER1","name":"Z4 Bedroom Windows","tags":"sensor,doorWindow","status":"devStatOK","statusTxt":"Z4 Bedroom Windows - Closed\nLast Activity: 7/12 10:49 AM","activityTs":1531406991636}
adt/zone/Z5 Back Doors/state {"id":"sensor-13","devIndex":"E5VER1","name":"Z5 Back Doors","tags":"sensor,doorWindow","status":"devStatOK","statusTxt":"Z5 Back Doors - Closed\nLast Activity: Today 4:50 PM","activityTs":1531687815325}
adt/zone/Z6 Family RoomMotion/state {"id":"sensor-14","devIndex":"E6VER1","name":"Z6 Family RoomMotion","tags":"sensor,motion","status":"devStatOK","statusTxt":"Z6 Family RoomMotion - Okay\nLast Activity: 1/22 5:41 PM","activityTs":1516660888847}
adt/zone/Z7 Laundry Room Smoke/state {"id":"sensor-8","devIndex":"E7VER1","name":"Z7 Laundry Room Smoke","tags":"sensor,fire","status":"devStatOK","statusTxt":"Z7 Laundry Room Smoke - Okay\nLast Activity: 5/27 9:47 AM","activityTs":1527428852554}
What happens when you run the following. Do you get the output for all your MQTT devices?
mosquitto_sub -h YOUR_MQTT_IP -v -t "#"
