ADT Pulse integration
If you want to have the status change you can do something like this in your sensors page:
platform: mqtt
    name: "Master Bedroom Window"
    state_topic: "adt/zone/Master Bedroom Window/state"
    payload_on: "devStatOpen" # Use devStatTamper for shock devices
    payload_off: "devStatOK" #
    retain: true
    value_template: >-
      {% if is_state('sensor.master_bedroom_window', 'devStatOpen') %}
        Open
      {% else %}
        Closed
      {% endif %}
What exactly is the value of what youā€™re describing here?
Sorry - Iā€™m still learning :slight_smile: Thanks!
Hey Ben, to use this - does the sensor.master_bedroom_window need to be created elsewhere?
Meaning, doesnā€™t there need to be a configuration that calls for a friendly name and that name would be master_bedroom_window?
Sorry for the obvious question if Iā€™m missing it.
Youā€™re replicating the functionality of the binary_sensor. Personally, Iā€™d just use binary_sensor with the example configuration shown further up above.
But in Benā€™s example, heā€™s changing the variable so that it shows open/closed vs on/off.
I think.
Correct. I used sensor instead of binary sensor , so my output was devStatOk and i didnt like that. So I grouped it and updated the code so that mine shows open/closed.
This is what mine looks like
i am still learning also and couldnt get it to work in binary sensor. And now i see why my code was wrong. Thanks for that. But if you use sensor you can use my code. I basically just did what binary sensor does just like e1miran said
This is the same as Arm_Stay_instant
So what does your code look like to name your sensor?
Really? You can issue that and it works? Thaā€™s great! Iā€™ll try this later.
@Ben_Ellis @commandcontrolit
Thatā€™s what device_class is for in binary_sensor. Plus there is the added benefit of showing the correct ā€˜open/closeā€™ icons for each class without having to configure them oneself. Just remember device_class only works with binary_sensorā€¦ not with the plain sensor.
I have the following configured in my binary sensors, and they all display state and icons correctly without me having to do any templating.
device_class: door
device_class: window
device_class: motion
device_class: smoke
Hereā€™s what my config looks like:
binary_sensor:
  - platform: mqtt
    name: "Z1 Entry Doors"
    device_class: door
    state_topic: "adt/zone/Z1 Entry Doors/state"
    value_template: '{{ value_json.status }}'
  - platform: mqtt
    name: "Z2 Master Bedroom"
    device_class: door
    state_topic: "adt/zone/Z2 Master Bedroom/state"
  - platform: mqtt
    name: "Z3 Front Windows"
    state_topic: "adt/zone/Z3 Front Windows/state"
  - platform: mqtt
    name: "Z4 Bedroom Windows"
    state_topic: "adt/zone/Z4 Bedroom Windows/state"
  - platform: mqtt
    name: "Z5 Back Doors"
    device_class: door
    state_topic: "adt/zone/Z5 Back Doors/state"
  - platform: mqtt
    name: "Family Room Motion"
    state_topic: "adt/zone/Z6 Family RoomMotion/state"
  - platform: mqtt
    name: "Laundry Smoke Detect"
    device_class: smoke
    state_topic: "adt/zone/Z7 Laundry Room Smoke/state"
So please let me know what you need for the alarm panel ? i saw the email but lost it. I can provide that.
Also your motion should be devStateMotion
Thanks. Makes sense. Any idea what it should be for the smoke detector?
alarm_control_panel:
  - platform: mqtt
    state_topic: "home/alarm/state"
    command_topic: "home/alarm/cmd"
    payload_arm_home: "arm_home"
    payload_arm_away: "arm_away"
    payload_disarm: "disarm"
Thanks for sharing.
Folks,
I need your help on implementing Device support. I see some of you have smoke detector, lamps, cameras etc. Apparently there is a second page where you can see these devices. I donā€™t own any devices. So I donā€™t see anything (just a ā€œNo other devices installed.ā€ message),
If you own devices other than contact/motion sensors, do you mind sharing the output of the following page: https://portal.adtpulse.com/myhome/9.7.0-31/ajax/currentStates.jsp ?
Please submit your outputs to https://github.com/haruny/adt-pulse-mqtt/issues/11
Please mask out any of information you like for your privacy such as location names.
Thank you!
haruny.
Tried - doesnā€™t work.
I have no other devices. Sorry I canā€™t help. Happy to help with anything else you need testing with!
Are there instructions on how to install this manually? hassbian doesnā€™t have the addon feature.
Sorry Iā€™m not experienced in hassbian so I canā€™t provide step by step instructions.
It shouldnā€™t be different from any other addon however, there is nothing special to it. Probably doable if you change the config.json and server.js a little bit I suppose. There remaining parts has nothing special to it.
It would require you to run nodejs install in a docker container and run the server.js.
Seems like going the hass.io route would be the easiest in the long run, so Iā€™m planning to just flash the SD card with hass.io and port over my current install from backup.
Thanks!
