TIA. I am struggling to get Adguard installed. I am getting no results the logfile has alot but i cant see an obvious error.
My thoughts are how does adguard route traffic when it is installed after the router, so i surley need to have something setup to route traffic before the router , but i cant see anything in the documents that i understand.
Another note is that in the documentation point 6 says login, but i dont see this option.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: AdGuard Home
Network-wide ads & trackers blocking DNS server
Add-on version: 4.7.4
You are running the latest version of this add-on.
System: Home Assistant OS 7.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.9.6
Home Assistant Supervisor: 2022.09.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
Log level is set to ERROR
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/adguard.sh
cont-init: info: /etc/cont-init.d/adguard.sh exited 0
cont-init: info: running /etc/cont-init.d/discovery.sh
cont-init: info: /etc/cont-init.d/discovery.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun adguard (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
2022/09/26 21:26:52.809552 [info] AdGuard Home, version v0.107.13
2022/09/26 21:26:52.817222 [error] creating dhcpv4 srv: dhcpv4: is not an IP address
2022/09/26 21:26:52.833800 [info] Initializing auth module: /data/adguard/data/sessions.db
2022/09/26 21:26:52.834240 [info] auth: initialized. users:0 sessions:0
2022/09/26 21:26:52.834338 [info] Initialize web module
2022/09/26 21:26:52.837365 [info] DNS cache is enabled
2022/09/26 21:26:52.837419 [info] MaxGoroutines is set to 300
2022/09/26 21:26:52.874533 [info] AdGuard Home is available at the following addresses:
2022/09/26 21:26:52.874586 [info] Go to http://127.0.0.1:45158
2022/09/26 21:26:53.379757 [info] Starting the DNS proxy server
2022/09/26 21:26:53.379973 [info] Ratelimit is enabled and set to 20 rps
2022/09/26 21:26:53.380062 [info] The server is configured to refuse ANY requests
2022/09/26 21:26:53.380144 [info] DNS cache is enabled
2022/09/26 21:26:53.380233 [info] MaxGoroutines is set to 300
2022/09/26 21:26:53.380333 [info] Creating the UDP server socket
2022/09/26 21:26:53.380629 [info] Listening to udp://192.168.0.46:53
2022/09/26 21:26:53.380753 [info] Creating the UDP server socket
2022/09/26 21:26:53.380971 [info] Listening to udp://172.30.32.1:53
2022/09/26 21:26:53.381082 [info] Creating a TCP server socket
2022/09/26 21:26:53.381296 [info] Listening to tcp://192.168.0.46:53
2022/09/26 21:26:53.381401 [info] Creating a TCP server socket
2022/09/26 21:26:53.381626 [info] Listening to tcp://172.30.32.1:53
2022/09/26 21:26:53.381986 [info] Entering the UDP listener loop on 172.30.32.1:53
2022/09/26 21:26:53.381993 [info] Entering the UDP listener loop on 192.168.0.46:53
2022/09/26 21:26:53.382399 [info] Entering the tcp listener loop on 172.30.32.1:53
2022/09/26 21:26:53.382357 [info] Entering the tcp listener loop on 192.168.0.46:53
