Update: the ERIA isn’t so much “sleepy” as it is overly chatty when it wakes up. The events below were blasted out by the remote over the course of just a few seconds. All of these events are identical except for the timestamp & GUIDs. So the question is: why does it go crazy with redundant events like this just because it’s been a while since the last event it fired?
Event 12 fired 10:59 AM:
"event_type": "zha_event",
"data": {
"unique_id": "00:15:8d:00:01:98:d3:e2:1:0x0006",
"device_ieee": "00:15:8d:00:01:98:d3:e2",
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:53.760485+00:00",
"context": {
"id": "373abb01d7b7442b98668a30bf1e0476",
"parent_id": null,
"user_id": null
Event 11 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:46.339465+00:00",
"context": {
"id": "a20fb90d735d48fcbd556b7a9086e796",
"parent_id": null,
"user_id": null
Event 10 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:43.737715+00:00",
"context": {
"id": "d0fa4e210cdf463cbfcb17797b3861a2",
"parent_id": null,
"user_id": null
Event 9 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:41.118648+00:00",
"context": {
"id": "94af0c87e2824d9a997a355f5c780caf",
"parent_id": null,
"user_id": null
Event 8 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:38.455991+00:00",
"context": {
"id": "6f82d6fbc76d4910ab91ea30634a93e8",
"parent_id": null,
"user_id": null
Event 7 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:35.776652+00:00",
"context": {
"id": "8ddc1255bf1d48fbaaf964c829da2584",
"parent_id": null,
"user_id": null
Event 6 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:33.111071+00:00",
"context": {
"id": "9f3bd7548e474df982ccc28abb11e6f0",
"parent_id": null,
"user_id": null
Event 5 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:30.412061+00:00",
"context": {
"id": "fcdb89a24f984280b67ee7917a502ce1",
"parent_id": null,
"user_id": null
Event 4 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:27.724411+00:00",
"context": {
"id": "3b7759b1537e42e0a68ecf28a7e9e78c",
"parent_id": null,
"user_id": null
Event 3 fired 10:59 AM:
"data": {
"endpoint_id": 1,
"cluster_id": 6,
"command": "off",
"args": []
"origin": "LOCAL",
"time_fired": "2020-02-03T18:59:25.060018+00:00",
"context": {
"id": "b8fbd378314945fa89435385bf053751",
"parent_id": null,
"user_id": null
