This is an advanced fan timer that is smarter than your typical auto off fan.
Note this automation requires you create a Timer helper first. If you want the timer to survive a HA restart then make sure you check the restore checkbox in the timer helper
Scenario 1
If fan has been enabled and no control light has been paired to automation than fan will count down from defined timer helper and shut off.
Scenario 2
If light is on or turned-on, fan will stay on until light is turned off then fan will start to count down from defined timer helper and shut off.
Scenario 3
If shower is turned on fan will turn on. Shower requires entity that identifies when shower is on. You can pick multiple shower inputs for room. I use Moen shower controller. When all shower heads are off fan timer counts down using defined timer helper unless control light is on.
Version 1.0 - New
Version 1.1 - Breaking update - To fix set fan watchdog. Default can be 0. Updated Blueprint title and added fan watchdog timer so that fan will turn off if on for x duration. This is a safety net in case someone leaves on the control light (when assigned). Do not make this timer shorter than the maximum time you will be in a bathroom. Something like 2 hours.
Version 1.2 - Breaking update - Removed hot water loop control as it is really not part of a fan timer automation.
Version1.3 - Breaking update - To allow for change of the timer duration you are now required to add an Input Number Helper for each timer. This will allow easy duration timer adjustments from cards.
blueprint:
name: Advanced Auto Fan Off
description: Home Assistant smart fan control with shower sensors
domain: automation
input:
fan_entity:
description: Fan to monitor and control
selector:
entity:
filter:
- domain:
- light
- switch
multiple: false
fan_entity_watchdog:
default:
hours: 0
minutes: 0
seconds: 0
description: Turn off after x duration no matter what is running (optional)
selector:
duration: {}
control_light_entity:
default: []
description: Light to monitor and control the fan (optional)
selector:
entity:
filter:
- domain:
- light
- swtich
multiple: false
shower_entity:
default: []
description: Shower(s) to monitor (optional)
selector:
entity:
multiple: true
filter:
- domain:
- light
- switch
fan_timer:
name: Fan Timer Helper
description: Timer Helper
selector:
entity:
filter:
- domain:
- timer
multiple: false
fan_timer_duration:
name: Fan Timer Duration Helper
description: Number Helper
selector:
entity:
filter:
- domain:
- input_number
multiple: false
source_url: https://gist.github.com/Jjbasso/be243f0ffef860d47f90239ac9271cb3
- platform: state
entity_id: !input shower_entity
to: 'on'
id: Master Bathroom Shower On
- platform: state
to: 'off'
id: Master Bathroom Shower Off
- platform: state
entity_id: !input fan_entity
to: 'on'
id: Bathroom Fan On
- platform: state
to: 'on'
for: !input fan_entity_watchdog
id: Bathroom Fan On Delayed
- platform: state
to: 'off'
id: Bathroom Fan Off
- platform: state
entity_id: !input control_light_entity
to: 'off'
id: Bathroom Light Off
- platform: state
to: 'on'
id: Bathroom Light On
- platform: event
event_type: timer.finished
id: Master Bathroom Lavatory Fan Timer Finished
event_data:
entity_id: !input fan_timer
variables:
shower_entity: !input shower_entity
fan_timer_duration: !input fan_timer_duration
- if:
- condition: trigger
- condition: state
state: 'on'
for:
hours: 0
minutes: 0
seconds: 5
then:
- service: homeassistant.turn_off
data: {}
- choose:
- conditions:
id: Bathroom Fan On
- condition: state
state: 'off'
sequence:
- service: timer.start
duration: '{{ states(fan_timer_duration)|float|multiply(60)|timestamp_custom(''%H:%M:%S'', false)
- choose:
- conditions:
id: Bathroom Fan On
- condition: state
state: 'on'
sequence:
- service: timer.cancel
data: {}
- choose:
- conditions:
sequence:
data: {}
- choose:
- conditions:
sequence:
- service: homeassistant.turn_on
data: {}
data: {}
- choose:
- conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'off'
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
sequence:
- choose:
- conditions:
sequence:
data: {}
- choose:
- conditions:
sequence:
data: {}
- choose:
- conditions:
- condition: template
value_template: '{{ expand(shower_entity) | selectattr(''state'', ''eq'', ''on'')
| list | count > 0 }}'
sequence:
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
data: {}
mode: single
