I can see that in the config file I can setup exclude and include settings, I am assuming that these basically say “don’t save x data in the recorder at all”, but is there a way of setting different polling rates/retention times/long term data retention / or whatever per … something? (or am I misunderstanding how that works?)
So, for example, something like the battery level of a sensor is probably only worth keeping for a shorter time, and maybe only worth polling say once per day or so (depending on the device), and something like an outside temp sensor might only need to be polled once per hour, but an inside sensor I might want to get a more minute by minute record to see how my hvac system is working. and I might want to keep some data as long as possible, but other data I may decide I don’t really need to keep them for more than a few days / weeks / months.
I realize that the effort to configure something like this would be high and probably not worth it for most (and honestly, I might not even do it myself), so I’m mostly interested in understanding if it’s reasonably possible (without custom coding).
