Before I started using AHC, I was using BT. However, I have already deactivated the individual virtual thermostats. The thermostat is set to manual, and no one else is accessing it.
Ok, but anything sets this abnormal temperature. Did you check your logbook, too? The only change from AHC is 23.5Ā°C set temperature, but not those values above the local thermostat temperature.
However, one thing is still not entirely clear. Today, everyone was out of the house, and I am not sure if the āaway temperature offsetā is working. Do you think the update I installed today will fix this? Can you check this based on my configuration? That would be my last point, then I wonāt bother you anymore!
Hi @panhans
Thanks for creating the blueprint!
I tried to go through all the conversations but there are to many to filter what is important for me and what is not relevant so my question might allready have been answered
I have a Danfoss Ally - changed āCalibration Entity Key Wordā to āexternal_temperature_sensorā. Seems to be correct but could you please confirm?
I still get below error which is not straigh forward for me to understand
I feel a bit overwhelmed by the number of options in the scope of what I would like to do. My scenario seems rather simple, but I am unsure on how to best tackle it:
I have a base temperature (BTP), when present.
Once per week, I need another temperature (WSP), per schedule, when present.
I would like to decrease to the temperature (A), when absent. It seems the away offset is not fit for that, is it? Or maybe switch off.
As the cherry on the cake, I would like to keep an option for a presence based schedule temperature (PBS).
Thanks in advance for helping me out there.
Somebody is home ā comfort
Nobody is home ā eco
Is this like the first point just with another comfort temperature?
If you set persons you can enable an option in temperature tweak section to turn the climates off if nobody is home or you can go with frost protection to lower the target temperature.
I think this can be done in the presence section easily, right?
Newbie here, Thought i could set each thermostat to a schedule and independent temperature but it seems the multiple schedules are for holidays etc, not TRVās. Am I right in thinking this can only control the entire house on a global temp and schedule?
Thanks for fast reply. Didnāt know I was already 4 releases (5.2.9) behind when downloading blueprint for about 4 days ago - you are working fast
Do I need to manually download an updated blueprint in the future to get updates or will it somehow popup that there is a new update?
@panhans
I am still using your blueprint and I really like it, big thanks again for this one!
I know that you created a documentation for this blueprint, but would you mind to share your setup with us? How have you setup your TRVs, your external sensors, the automation in general. Maybe a tutorial video on YouTube would really help to understand every aspect of the blueprint.
For example I didnāt know that you could create a sensor that shows the newest version of the blueprint.
I came back with some more test. Without persons etc. simple as possible temperature trigger is not happening. Temperature it changes, it triggers the automation but it doesnāt open the TRV.
Last two traces: Log-1 - Pastebin.com and Log-2 - Pastebin.com
Current config:
Would it be possible to add a custom time value for Liming Protection? My thermostat controls a valve, that needs several minutes, before it opens, when the thermostat sets heating to ON. I guess there is some kind of capacitor in that valve, because when the thermostat sets heating to OFF, the valve will close after a few minutes.
In this situation, the Liming Protection will not make any sense to me. What do you think?
You need at least an entity that triggers the comfort mode. Just take an input boolean for guest mode or presence sensor. With your configuration the eco temperature is always set.
