🔥 Advanced Heating Control
:fire: ADVANCED HEATING CONTROL :fire:
Features
🔥 heating / ❄️ cooling based on
    👥 people presence
    🗓️ multiple schedulers
    🚶 presence sensor
    ↔️ proximity aka geo fencing
🏃 away temperature offset
🥶 frost protection
😡 adjustable aggressive mode
🌤️ activation based on weather, temperature or boolean entities
🎛️ granular schedule adjustments
🪟 multiple window open detection
🎈 party mode
🤝 guest mode
🧭 thermostat calibration for the most common devices (Tado, Aqara, Popp / Danfoss / Hive, Tuya)
⚔️ liming protection
📍 dynamic valve positioning
⚙️ several tweaks for fixing your thermostat issues
🎬 custom action
🤫 calm & 💪 reliable
Advanced :fire: Control V5
4.0 | 4.1 | 4.2 | 4.3 | 5.0 | 5.1 | 5.2 | 5.3 | 5.4 | 5.5
AHC Template Sensor
  1. Copy this to configuration/blueprints/template/panhans/advanced_heating_control_sensor.yaml
  2. Add this to your configuration.yaml
template:
  - name: AHC Data
    unique_id: ahc_data
    use_blueprint:
      path: panhans/advanced_heating_control_sensor.yaml
      input:
        ahc_automation: automation.YOUR_AHC_AUTOMATION #edit this to your automation entity_id
  1. Navigate to your Developer Tools .
  2. Check and reload your YAML configuration.
Advanced Heating Control V4 (deprecated)
DEPRICATED
Development
Planned Features
  • :calendar: calendar support
  • :level_slider: more adjustable limits for aggressive mode
  • :man_walking: stagged away mode
  • :arrow_up_down: valve positioning
  • :point_up_2: selection for thermostats for generic calibration / aggressive mode
  • :control_knobs: entities for away temperature and thresholds (on/off)
  • :sun_with_face: evaluated sun condition for on/off toggle
  • :white_check_mark: custom condition to allow/block calibration
Thanks for testing, reporting and debugging to everyone especially: sben, sourdistorne, dario2 , coldspark29 , technikhaus, tirol3, stephanschleichstr13, bandit79, Mar1us, vajdum. Ziegelsandundspucke, mukrop, k-dani, allard77, hainfelder, Appox, NikB, kitus, David883, P6Dave, fir3dragon, DenisLanz, CarstenJ, tco95ttocs, Rapha0000, NoBadDays739
Hints & FAQ
FAQ
Hints
To make long entering / leaving durations for persons and open / closing durations for windows work properly I recommend to setup the uptime integration.
Open your Home Assistant instance and start setting up a new integration.
Troubleshooting
  1. Check if you're running the latest version.
  2. If it's the case, describe your problem.
    1. What do you want to achieve?
    2. What doesn't work?
  3. Set debug level to warning
  4. Trigger you automation or let it run into your issue
  5. Save and share your tace log for example here
  6. Give me some time to check :wink:
INFO: Don't set an external temperature sensor and avoid using generic calibration or aggressive mode if you wrapped your climates in Better Thermostat.
How do I get a trace log?
  1. Navigate to your automations
  2. Find your automation and click on three-dots-menu
  3. Click on traces
  4. Select a trace with the upper arrows
  5. Click on three-dots-menu again
  6. Click on download trace
Also you can create issues on my github repo.
Helpfull Snippets
Calendar Based Scheduler Selector Sensor
Here is an example for my template based binary sensor for holidays. There are two calendars. One holds the national holidays for my region and the other one is my personal calendar. The sensor scans for national holidays and a catchphrase for my personal one.
template:
- trigger:
    - platform: time_pattern
      minutes: /10
  - service: calendar.get_events
      start_date_time: "{{ now().replace(hour=0,minute=0,second=0,microsecond=0) }}"
      end_date_time: "{{ now().replace(hour=23,minute=59,second=59,microsecond=999999) }}"
      entity_id:
        - calendar.family # edit this for your calendar entites
        - calendar.holidays
    response_variable: calendar_events
  binary_sensor:
  - name: Holiday
    icon: mdi:palm-tree
    unique_id: holiday
    # here you can add a catch phrase as regex also if the holiday calendar has an event the state of the sensor will be on
    state: >
        ( calendar_events['calendar.family'].events | regex_search('holiday', ignorecase=True) ) or
        ( calendar_events['calendar.holidays'].events | count > 0 )
If you have questions or feature request, feel free to comment this thread.
Greets!
References
UI inspired: Cover Control Automation (CCA) - Intelligent Automation for Blinds, Awnings & Shutters | Calendar, Sun Shading, Force Functions
My Blueprints
:fire: Advanced Heating Control
:next_track_button: Simple Scene Toggle
:speech_balloon: Entity State Notification
:globe_with_meridians: Zone Notification Extended
:clapper: Scene Based Theatre Mode
🌐 Zone Notification Extended
💬 Entity State Notification
Temperature is jumping from SONOFF thermostat
Heating scheduling with presence detection
Moes BRT-100 TRV does not respond to temperature change request
Which climate / heating integration for HA with fritz dect 301
🧠⁺ Smarter Thermostat
Versatile Thermostat: a full feature thermostat (energy, door/window, presence, motion, preset, ... management)
Bosch Thermostat 2
Tuya radiator valve (TS0601) calibration from external sensor (via zigbee2mqtt)
Tado smart thermostat + zigbee TRV valves
Heating management blueprints (DEPRECATED)
Request for Generic Thermostat "heater" switch to act as a thermostat physical switch
Smart heating system HA
[BLUEPRINT] Adaptive Climate Control - ASHRAE 55 Implementation with Energy Optimization
[Custom Integration] Home Performance - Analyze your home's thermal performance and insulation quality
Notify device or group | execute action based on binary_sensor with debounce option
[SmartHRT] Smart Heating Recovery Time - (Cool Sleep, Warm Wake-Up!)
Best Thermostat (TRV) for Advanced Heating Control blueprint
WTH are we missing support for underfloor heating?
WarmMe Intergration (Tuya?)
Tado Integration Stopped Working
Heating/Cooling blueprint for dual-zone setup?
Tado Integration - Authentication does not work anymore
🔌 Smart Climate Switch with Occupancy Control
Multiple per Thermostat Schedules
Aqara W500 floorheating thermostat
Overview: Solutions for Climate, Heating, Humidity, HVAC Regulation and Automation
Automatic (open and close after time) different windows - Tado and Velux
I do not trust my Bosch thermostats
Is there a way to add Headlines / Separators / Sections in Blueprint UI
Winter routines at home — heating and lighting as the days get shorter
very nice. Is it possible to switch back to the previous temperature after x hours of manual intervention?
Maybe you can trigger the heating automation using another like this:
description: ""
mode: restart
  - platform: state
    entity_id:
      - climate.your_trv
    attribute: temperature
condition: []
  - delay:
      hours: 2
      minutes: 0
      seconds: 0
      milliseconds: 0
  - service: automation.trigger
    data: {}
      entity_id: automation.your_heating_automation
Hi panhans!
Thanks for providing this! I tried implementing it today, but I failed. First one obvious thing:
The window entity is not optional and I am not able to save the automation if I have no window sensor.
I fixed that by creating a new sensor, which extracts the window detection of my thermostat (Fritz! Thermo)
binary_sensor:
    sensors:
      windowhelper:
        unique_id: d62d73da-7839-4cb4-8dd4-5a83b1f52923
        friendly_name: "Heizung-Helfer-Fenster-Proxy"
        device_class: window
        value_template: "{{ state_attr('climate.wohnbereich_linkes_fenster', 'window_open') }}"
But it didn’t help:
No matter what I try, the automation always sends an off state to the thermostat.
Do you have any idea, what I am doing wrong?
My config:
(both winter_mode and party_mode entities are helpers and set to off, at least one person is present, window state is closed, schedule is marked 9-22)
Hmm, I have one automation without window running atm. I’ll try to set up a new one.
If winter mode is off heating is always off. Try to set it to on.
That works, thank you! I am used to something like “Summer-Mode”, so my thinking got mixed up.
Great work! Super easy to set up and works as intended!
Nevertheless, the party mode doesn’t override my schedule. Is it a known issue or do you need further details?
I’d faced that issue a few days ago and fixed it this week. Maybe you try to update the blueprint.
Works like a charm! Thank you!
thx you very much, it works great,
would it be possible to make this work with a separate temperature sensor?
What should the external sensor do? Do you want the outside temperature to turn on/off heating?
thx for your answer,
i hoped to use a different temp sensor for the room,
my thermostats temperature is reporting way to high degrees. (i tried to offset the temperature, but its a total mess)
with an option for a different room temp sensor, one could just simply choose a sensor of choice.
hope that makes sense
This blueprint only controls temperature. There are other blueprints/automations for your issue. It also depends by your valves, integration and calibration attribute.
The most calibration automation can be used parallel to this blueprint. If you’re using tuya and z2m this thread could help you:
@panhans: I am just trying your blueprint as well. Why don’t you have multiple window entities? Like this you have to create a template and combine all window contacts if your room has more than one. I just made a new one and changed it to multiple. I would also like to add thermometers to the blueprint, that are used as current temperature, because the ones at the valves are not a good choice in some cases. Will see how I can do that
  1. Home assistant blueprints cant handle multiple optional entities used as trigger entities. There is an issue opend for that and also some threads here in the community but for most people not a big thing. Dont know if its ever be possible. So I must decide if I go with one optional window entity or multiple window support. Since some people use the build in window open mechanism I decide to chose the first option. Other blueprints are using time based periodical checks but I am not a friend of this kind of polling.
  2. For using an external temperatur entity for calibration I wrote something one post above. Since this is much wanted I will dive into to see what I can do for this blueprint.
Ah yes, just setting the windows to multiple breaks the automation. Pity that this isn’t supported.
Haven’t read your post above. Will have a look into it. Thx
And you dont need a template. Simply create a helper and group your windows and select this group as your window entity. :wink:
Yes, thank you. Works like a charm
The blueprint is great apart from that. I could get rid of my complicated automations. I had one automation for turning the heaters on and one for turning them off. Horrible…
When the external temperature sensors are implemented, the blueprint will be perfect! :wink:
Hey!
Thanks for this amazing blueprint, I got one question.
My EvoHome Systems requires the preset mode to Permanent otherwise it will follow a strange inside build schedule…
How can I add the preset mode to the Blueprint?
For Example, HVAC Mode Heat + Preset Mode: Permanent
Second question is, I can’t set the temperature to 19.5 in the Blueprint, am I doing something wrong?
Hope you can help me out with this!
I found something like this that works for me but I am not sure where I can leave this code in the blueprint:
service: climate.set_preset_mode
preset_mode: permanent
entity_id: climate.living_room
