Nothing changed between those two versions in the xiaomi / aqara calibration logic. Also the temperature calibration value is reported to the calibration entity definitely. So the 19.4° must be the value of your temperature sensor except you’ve enabled aggressive mode over calibration.
Unfortunately the error in your log just shows there is an error but not what causing it or what exactly doesn’t work.
Maybe you could trigger the calibration by holding the sensor in your hands. After that save the last 5 trace logs. (Have a look into the first post / toubleshooting section)
I updated to 5.2.16 and also did a completly new automation. I will report back how it behaves
I habe a problem with the “Person” in the blueprint. The Person ist nit recognized as not at home.
The heating is on, but my wife is not at home
The Person itself is showing not at home.
I’m using Version: 5.2.15
Where is my error?
(sorry, only allowed to show one pic here …)
Have a look into the troubleshooting section in the first post, please.
You’ve enabled generic calibration.
Target temperature: 20° ← ECO Temp because nobody is home
Room temperature: aprox. 21°
Measured thermostat temperature: 23°
Difference between thermostat & room temp: 23° - 21° = 2°
Corrected target temp: 20° + 2° = 22° ← this is the corrected ECO temp
Corrected ECO temp < Measured thermostat temperature = 22° < 23° → means your valve is closed / no heating
Everything is fine here.
Ah, ok, as long as the shown temp is lower than the actual temp heating is stopped. I misunderstood that.
Thanks a lot for your helb and the Blueprint!
