Could you check out and test again?
I also discovered that. It heats sometimes over the target temperature. Iâll try to find a workaround in my blueprint (Automate your Bosch Thermostat 2). The blueprint from @panhans is a bit overkill for me anyhow
yes, I will test it the next days and come back with results
Here you go -
Off Instead Of Minimum Temperature enable but trv is idle
Could you share the number of the version you are using? Additional a trace log downloaded after executing the automation would be great. (See initial post)
still trying to figure out why one of my Airzone climate entities is not getting triggered by the automation. When I read your answer I enabled splitting but for some reason the automation would no longer activate my heating system when I was expecting it to be, and I rolled that back. I have just enabled it again and reduced the service call spacing, hoping to see if by tuning the service call spacing, I get the results Iâm after.
In the mean time, I noticed something in the logs. In particular, âhab_polâ has triggered 140 occurrences this week and it is the climate entity preceding the entity that was originally not getting activated by the automation.
Logger: homeassistant.components.automation.automatic_heating_v4_hab_pol
Source: helpers/script.py:476
Integration: Automation (documentation, issues)
First occurred: January 28, 2024 at 6:31:10 AM (140 occurrences)
Last logged: 6:31:10 AM
Advanced Heating Control v4 - Airzone: Choose at step 4: default: If at step 1: If at step 1: If at step 2: Error executing script. Unexpected error for call_service at pos 1:
Advanced Heating Control v4 - Airzone: Choose at step 4: default: If at step 1: If at step 1: Error executing script. Unexpected error for if at pos 2:
Advanced Heating Control v4 - Airzone: Choose at step 4: default: If at step 1: Error executing script. Unexpected error for if at pos 1:
Advanced Heating Control v4 - Airzone: Choose at step 4: default: Error executing script. Unexpected error for if at pos 1:
Advanced Heating Control v4 - Airzone: Error executing script. Unexpected error for choose at pos 4:
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 713, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 675, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 2149, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2186, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 272, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 907, in entity_service_call
raise result from None
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1497, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 952, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 731, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/airzone/climate.py", line 224, in async_set_temperature
await self._async_update_hvac_params(params)
File "/usr/src/homeassistant/homeassistant/components/airzone/entity.py", line 203, in _async_update_hvac_params
await self.coordinator.airzone.set_hvac_parameters(_params)
File "/usr/local/lib/python3.11/site-packages/aioairzone/localapi.py", line 499, in set_hvac_parameters
res = await self.put_hvac(params)
File "/usr/local/lib/python3.11/site-packages/aioairzone/localapi.py", line 473, in put_hvac
return await self.http_request(
File "/usr/local/lib/python3.11/site-packages/aioairzone/localapi.py", line 159, in http_request
resp: ClientResponse = await self.aiohttp_session.request(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 500, in _request
with timer:
File "/usr/local/lib/python3.11/site-packages/aiohttp/helpers.py", line 735, in __exit__
raise asyncio.TimeoutError from None
TimeoutError
Coincidentally, the climate entity that was not getting started by the automation was the last one in automation definition:
alias: Advanced Heating Control v4 - Airzone
description: ""
use_blueprint:
path: panhans/heating_control_v4.yaml
input:
input_trvs:
- climate.a_comedor
- climate.a_h_jan
- climate.a_h_noah
- climate.a_h_pol
- climate.a_h_suite
[CONFIG CONTINUES]
I just changed the order and left hab_pol as the last entity in that list. No idea if this means that hab_pol will be the last entity to be triggered by your automation, but if it is the case, any error from hab_pol crawling up during execution, wonât have an impact on problematic entity âh_suiteâ.
description: ""
use_blueprint:
input:
input_trvs:
- climate.a_comedor
- climate.a_h_jan
- climate.a_h_noah
- climate.a_h_pol
- climate.a_h_suite
[CONFIG CONTINUES]
Even if changing the order might mitigate the issue and allow for the automation to activate the impacted entity, I think understanding this error message is important as it may help improve the blueprint and or the Airzone integration.
@panhans is there anything in that log error message that may lead to any conclusion? There clearly is a message suggesting a service_call failed
Iâm crossing my fingers hoping the reduced spacing in the service call split option is the way anyway.
Hi @panhans, I set up the ref version again for aqara thermostat. It seems that its running without issues so far. Great!! I also set up a version with two bosch thermostats in one room with v4 beta6 which also works as expected. One more question about the automation: If I not fill in minimum and maximum static temperature I be able to set up temperature by myself in UI or manual right? best regards!
Looks to me the REST api behind your integration returns an HTTP error.
The order of the trvs has no impact. Try to disable all automations, navigate to dev tools and try to set the hvac mode of your climate using a service call and look if the error occurs again.
I donât think its blueprint dependent. But a trace log whe error occurs is always welcome but be sure the trace you share results in that error.
Did calibration of the bosch trvs works out of the box or didnât you check the calibration?
If you want to adjust the comfort temperature in the ui you have to go with a helper. I personally just use a helper for comfort temperature. The one for minimum was requested by someone.
After a while it seems calibration does not work as expected. If I was running automation first everything looks nice. But now the calibration does not work correctly. You can see it below âHeizungâ in the cards. On the left side there is calibrated temperature on thermostat and on the right side target temperature. First screenshot is Bosch with two thermostats in one room, second one aqara.
Whats exactly wrong? Target is 19°C, right? Room temperature 19.9°C and vavles are nearly closed. Donât forget heating systems are some kind of sluggish. The radiator is still hot when target is reached, the valve closes but the room still heats up a little until it holds the temperature level stable.
//Edit: the values of the number entities for calibration would be interesting
Yes, but should the calibrated temperature in thermostat after offset calibration not should be the same (or nearly the same) as room temperature?
Values: I am just a litte noob, could you explain how to find out?
This is what z2m shows for states:
âbatteryâ: 100,
âboostâ: âOFFâ,
âchild_lockâ: âUNLOCKâ,
âdisplay_brightnessâ: 7,
âdisplay_ontimeâ: 10,
âdisplay_orientationâ: ânormalâ,
âdisplayed_temperatureâ: âmeasuredâ,
âlinkqualityâ: 255,
âlocal_temperatureâ: 19.5,
âlocal_temperature_calibrationâ: -1,
âoccupied_heating_setpointâ: 19,
âpi_heating_demandâ: 85,
âremote_temperatureâ: 0,
ârunning_stateâ: âheatâ,
âsetpoint_change_sourceâ: âexternallyâ,
âsystem_modeâ: âheatâ,
âupdateâ: {
âinstalled_versionâ: 889787668,
âlatest_versionâ: 889787668,
âstateâ: âidleâ
âvalve_adapt_processâ: false,
âvalve_adapt_statusâ: âsuccessâ,
âwindow_openâ: âOFFâ,
âupdate_availableâ: null
âlocal_temperatureâ: 19.5, â Calibrated meassured temperature
âlocal_temperature_calibrationâ: -1, â Offset (Difference to external sensor)
âoccupied_heating_setpointâ: 19, â Target temperature
It seems the calibration only allow full rounded values. So you always have a delta of +/- 0.5°C.
//EDIT: but youâre may right my calibration also doenst work as expected. seems in the refactored version is a little bug.
Maybe a hint. But Bosch also allow 0,1 steps. But I used the option force to full rounding in blueprint. I now deactivated it and will see if it has an impact. (For Bosch setup I use v4 beta6)
But there seems to be an issue with calibrating in ref version (I test it with aqara setup). Room temperature is 17,9, target temperature 19 and calibration says 19,1 so its not really heating. If you want to have a look, heres the trace log: be202f70 - SyntaxError: JSON.parse: unterminated string at line 717 column 70 of the JSON...
Could you reimport the refactored blueprint, please? There was a comment in the version before that result in a faulty trace log.
As I understand the aqara and bosch gets calibrated by just set the current temperature in its number entity. So there is no calculation needed.
What I donât get is that calibration of the bosch work. I never implemented this. Are you sure the calibration of the bosch thermostats isnât be done by another integration / blueprint?
You could enable debuging by adding some lines in you configuration.yaml (exxplained initial post). Then youâve got some more logging information including the values when calibration got set.
//EDIT: The bosch should work like mine also should work with previous versions.
Yes, Bosch offers local_temperature_calibration and offset. And in your description you say external sensor works with calibration and offset, so I wanted to give it a try
But what I do not get is the controlling of Bosch. Temperature is 20,2, target is 19,5 and all valves are nearly fully open But your automation works what I can see. I will try it with debug mode next week and try to jump a little deeper to find out what really happen in the code.
Yes, thats weird. If I understand the documentation of z2m and the bosch implementation correctly the calibration works like the one of TUYAs ect. It provides a number entity and accepts values in a range between -5 and 5 °C.
My Tuya thermostats are also very sliggish. They react if the room temperature differs 1°C to target. That means the heat till 21°C when target is 20°C. Thatâs why there is the aggressive mode. I will make this adjustable this evening. But without aggressive mode my thermostat will start/stop heating only if there is a big temperature difference.
Hi! Is it possible to use helper (which is the average of multiple temperature sensors), as Temperature Calibration Sensor?
Not, now. But I will add it to my feature list. As a workaround you can create a average template sensor. If you need help let me know.
