As I can see Lilli passed the 8000m at 20:27. State towards was already set. So you have set a duration of 2 min. So comfort heating should be set at 20.29 and 20:34 she was at home. All in all comfort heating should started only 5 min before she arrived at home.
Regarding the graph you could set the distance to 15.000 m or also include the location in the radius. (20.000 m)
EDIT: If you setup an AHC sensor for you automation you could display the state of this sensor together with distance and direction in the history.
Did test again today, and it looks like there might be blocking on “person not home”, but thats a guess. i had a lift home today, and was able to track the states in HA, and it looks like that I must “home” for it to trigger
No, you can add as many thermostats in a automation as you want. But it makes only sense if all thermostats has the same heating schedule. If not just create one automation per room where you add only the thermostats that are physically in that specific room.
Hi, this doesn’t seem to be working or is my configuration wrong? At 1pm the Eco temperature is not raised.
Another small question, is there a big difference between generic calibration and offset calibration via the thermostat (if it can do that, in my case Sonoff)? Which should I use better?
Could you share your configuration in yaml? I also use that feature for my bathroom to set the eco temperature to another value.
If your Sonoff provides calibration just go with the native calibration. The generic calibration manipulates the target temperature so your thermostat never shows the correct target temperature except the calibration offset is 0°.
How did you know that the eco set doesn’t work for you? Did you check the history of your external temperature sensor? The target temperature of your thermostat was manipulated because of the generic calibration.
If you have 12 room, 12 thermostats, 12 different requirements, then yes. If not you can group them and you’re good to go with only one automation per group.
I always get a notification when the target temperature changes and it doesn’t do that at 1 pm when nobody is at home. When I get home at 2:15 p.m., I immediately get a notification that the target temperature has been raised to Comfort 22 degrees
it looked like it was working for all rooms, but since one of the latest versions, it looks like something is broken.
E.g. when I run the automation for the kitchen, the temperature is put to 5 degrees while it should go to the ECO temp (16 degrees), the same in another time window when it should be set to Comfort (19 degrees).
Checked with other rooms, disabled the Legacy Restore, Window detection, etc. All doesn’t make a difference.
I wanted to add a trace to this, but only can find the option to upload pictures…
