Im not 100% sure with the âCalibration Entity Key Wordâ feature.
What is the right âCalibration Entityâ? my thermostat or my external sensor?
the external sensor is already the âRoom Temperature Sensorâ so i need to add again this one?
Edit: aah the âRoom Temperature Sensorâ is for âEnable Room Temperature Thresholdâ
as far as I understand it:
Calibration Entity is the entity of the thermostat, where calibration can be changed.
AHC looks for an entitiy that includes the keyword.
(Seems to be a clever workaround to adapt to many different thermostats)
In one case the calibration entity was named âexternerâ (external in german) ⊠by setting the âCalibration Entity Key Wordâ we can tell AHC what to look for.
(this was the logic before already - only now we can change the keyword in the UI.)
Yes, not needed. There are some users who localize the IDs. Thats why the default entity_ids doesnât match the algorithm anymore. In this case the key word must be changed to make calibration work again.
Great blueprint!! Congrats. I have set it up last week and I am very happy. I am using the proximity integration to track my Home zone. The only issue I am having is when I go out from home for a short period of time, letâs say 1 h, and the heater turns off. I prefer to maintain it on. To try to fix it, I have created another zone that is centered in my home but with a larger radius, letâs call it âhome wideâ zone. The idea is that if I am both at âhomeâ or at âhome wideâ zones, the heater is on. If I set in the blueprint proximity filed the âwide zoneâ, it is not working when I am at home, as I am detected at home, but not at home wide. Maybe it is an issue with two overlapping zones, that selects the smaller. To make it work, it would require that the proximity section of the blueprint allows to track two zones, not only home. Is it possible to do that, or do you see an alternative? Thanks in advance.
hi guys, i have a quaestion about the sheduling. At the moment i have several schedules, for example ânormalâ and âholidayâ. At the moment i have to change them with the schedule selector. Would it be possible to integrate the workday integration to this blueprint, so that it will automaticaly switch between ânormalâ and âholidayâ or weekend?
Just a warning (see FAQ in the first post). Its for calibrating Tado thermostats and without the integration spook gives a warning. You can simply ignor this.
im still on 5.0.rc1_g, and it looks like the spook messages are away, dont know why the messages comes before always after a reboot, so i cant check your new version, but i update to it (but the changes in the code looks right )
Regarding the spook documentation spook wonât throw warnings about templates. So Iâd just put the action into a template. A test with a simple automation worked for me.
I tried to test the DEV version and re-entered the data from one room.
But it seems that the window/door detection doesnât turn the TRVs to off after the reaction time.
As far as I can see the scene is created but the TRVs remains at the comfort temperature.
In case needed please find the trace: https://controlc.com/6bce5721
The other way round seems to work, as if I set the TRV manual to off and close the window, the created scene is applied and the TRV goes back to heat state.
As an additional note, the missing uptime integration mentioned in the trace log has since been added, but the behaviour remains the same.
