So i’ve been tinkering with this idea for a few days now. And instead of figuring out everything myself, I’d like to have your opinion/thoughts about this.
The idea:
Have Home Assistant send a greeting to the Google Home speakers when someone arrives at home. The greeting should give a short summary of the things you’ve ‘missed’ while you where gone.
For instance:
- Motion detections on the camera’s
- Temperature
- Battery states <10%
- Power/Gas usage
- Solar panel production
- If the vacuum ran while I was gone
Please note, these are just examples.
Most stuff isn’t really that hard, but for the motion detections on the camera I need a way to summarise the amount of triggers in the period I was absent.
I’ve been thinking to tackle this in several ways:
Method 1:
- Start timer sensor if ‘tracker_me’ is ‘away’
- Use jinja to calculate summary based on timer sensor from step 1
Method 2:
- Use the history component in some way I can calculate the state change
- Use period to calculate summary of number of events.
Method 3:
- Create seperate sensor of camera to count motion if ‘tracker_me’ is ‘away’
- Wipe stats after 20 min if ‘tracker_me’ is ‘home’
Are there better ways of configuring this?
Has anyone already have a system up and running like this?
