Hi there,
I am using my vacuum robot on 2 stories in our house. Running up & down with the unit a few times per week beats another €500 (for now).
The unit is rooted with Valetudo and have installed maploader which works great.
Also have this card in lovelace:
type: vertical-stack
cards:
- type: custom:auto-entities
card:
type: entities
state_color: true
title: Rooms to Vacuum BGG
filter:
include:
- group: group.vacuum_rooms_bgg
exclude: []
show_empty: true
sort:
method: entity_id
reverse: false
numeric: false
- type: custom:button-card
tap_action:
action: call-service
service: script.vacuum_clean_segments_bgg
confirmation: true
service_data: {}
target: {}
lock:
enabled: >
[[[return states['group.vacuum_rooms_bgg'].state !== 'on' ||
states['vacuum.valetudo_z10pro'].state !== 'docked']]]
exemptions: []
entity: script.vacuum_clean_segments_bgg
name: Vacuum selected segments BGG
show_state: false
show_icon: false
which has a lock based on the unit’s state and whether any individual segments are selected for cleaning. I’d now like to add the following condition as part of the locking conditions:
states['select.vacuum_maploader_map'].state !== 'main'
How do I add this with correct formatting?
Spoiler - this does not work:
states['vacuum.valetudo_z10pro'].state !== 'docked' ||
states['select.vacuum_maploader_map'].state !== 'main']]]
Thanks in advance, Joost
petro
(Petro)
June 11, 2024, 11:38am
2
That’s not Jinja. That’s JS.
How you added it is correct. Assuming you want or. If you want and, that’s different logic.
How about explaining what you want with words.
states[‘group.vacuum_rooms_bgg’].state !== ‘on’
or
states[‘vacuum.valetudo_z10pro’].state !== ‘docked’
and
states[‘select.vacuum_maploader_map’].state !== ‘main’
A simple working prototype:
cards:
lock:
enabled: >-
return states["input_boolean.testing_boolean"].state !== "on" ||
states["input_boolean.testing_boolean_2"].state !== "on"
exemptions: []
entity: sun.sun
- type: entities
entities:
- entity: input_boolean.testing_boolean
- entity: input_boolean.testing_boolean_2
What you need to do is defining a proper logic conditions.
Its all OR that’s needed -
**or**
**or**
As per the spoiler alert, the card does not display the button (locked or unlocked) if I add this extra condition…
I am I formatting this right?
JP
So just to be clear - the following results in the button-card NOT to display:
tap_action:
confirmation: true
service_data: {}
target: {}
lock:
enabled: |
exemptions: []
show_state: false
show_icon: false
This DOES display the button card:
tap_action:
confirmation: true
service_data: {}
target: {}
lock:
enabled: |
exemptions: []
show_state: false
show_icon: false
I see strange “quotes” here.
To display or not to display a “lock” icon (& make this button “disabled”).
Good gracious. I wish everything in life was THIS easy. Just use the right quotes and… DONE!
Thanks Ildar!
So correct JS code as follows:
tap_action:
confirmation: true
service_data: {}
target: {}
lock:
enabled: |
exemptions: []
show_state: false
show_icon: false
