I am the admin of my home assistant environment and I activate the Advanced Mode in my toggle
but in the Sidebar there is no change in menu or something else.
How can I get back my rider add-on as an example?
Actual I am not able to install any add-ons because the rider is invisible and to active the toggle shows no
new sidebar entry.
I have a similar problem I canât find any info about. My advanced mode switch simply doesnât work. I can turn it on/off for a user but that doesnât affect the UI in configuration->general. Any ideas?
Iâm having the same issue. Iâm on an RPi 4, HassOS 4.8. I noticed it only seems to affect my Add-On Store. I am able to perform other âadvancedâ tasks such as checking my config file and rebooting different integrations, etc.
I was able to find a solution to this thanks to Vincent from Discord. Youâll need to connect to the command line of your HomeAssistant, in my case connecting directly to the Pi - since I donât have access to SSH addons. Login by typing root as username. No password.
