Advanced Ring Keypad V2 Blueprint for Home Assistant (Alarmo)
This blueprint synchronizes a Ring Keypad V2 with Home Assistant and Alarmo. It builds upon previous work from ImSorryButWho but includes significantly more advanced features like environmental alarms, post-alarm warnings, customizable panic buttons, and rich mobile notifications.
Features
- Full Alarmo Sync: Perfectly syncs Armed, Disarmed, Arming (Exit Delay), and Pending (Entry Delay) states.
- Custom Alarmo Mode Mapping: You can independently map the keypad’s physical “Arm Home” and “Arm Away” buttons to specific Alarmo modes, including Home, Away, Night, Vacation, or Custom.
- Actionable Mobile Notifications (Optional): Receive interactive iOS/Android notifications directly synced with your alarm.
- Dynamic Buttons: Notification action buttons automatically inherit your configured
keypad_arm_home_mappingandkeypad_arm_away_mappingchoices. - Persistent Resend Logic: Intercepts
mobile_app_notification_clearedevents. If you accidentally swipe away an active alarm notification, it automatically resends to ensure you don’t lose access to the quick actions. - Platform Enhancements: Leverages Android custom channels, UI colors, dynamic status icons, and custom vibration patterns, as well as iOS
thread-id/apns-collapse-idgrouping. (Disclaimer: not all advanced visual features work on all phones/OS versions).
- Auto Force Arm on Open Sensors (Optional): If arming fails due to open sensors, a customizable countdown timer will begin. If left unresolved, the blueprint automatically bypasses the open sensors and force arms the system. The countdown can be canceled pressing the cancel option in the notification.
- S2 Security Collision Workaround: Includes a customizable delay toggle (0-3 seconds) to prevent the Z-Wave race condition (#4879) that causes the keypad to flash a red network error and fail to update its status when disarming.
- Bypasses Z-Wave JS Limits: Uses raw
invoke_cc_apicommands to bypass Home Assistant’s strict indicator filters, ensuring all special alarms actually work. - Environmental Alarms (Optional): Connect your environmental sensors (Smoke, CO, Moisture, Gas, Heat). If any of these trigger, the keypad will sound the loud, permanent Fire/CO siren until disarmed. You can leave this blank if you don’t have any, and the blueprint will still work perfectly.
- Smart “Post-Alarm” Warning: If your burglar alarm triggers while you are away, the siren will sound. When the alarm times out and re-arms itself (make sure this is enabled in Alarmo), the keypad will flash the Medical button as a silent warning/indicator. When you come home, you instantly know an incident occurred before you even enter your code!
- Custom Panic Buttons: Map any Home Assistant action to the physical Fire, Police, and Medical buttons on the keypad (Requires holding the button down for 3 seconds).
- Local Panic Sirens: Independent toggles allow you to choose whether holding a panic button also activates the keypad’s internal siren/flashing lights, turning it into a true standalone panic station.
- Presence-Based Actions (Optional): Select people and a zone to run separate actions when everyone arrives or leaves. Independent, default-off toggles can arm Alarmo Away when everyone leaves (only if currently disarmed) or disarm it when everyone arrives (only if currently armed). Away arming starts as a normal, non-forced attempt. If open sensors block it, the existing Auto Force Arm on Open Sensors setting controls whether its countdown begins and force-arms if the sensors remain open. Unknown/unavailable people do not count as having left.
- Custom Keypad Sounds (Optional): Set up to three independent trigger-to-sound mappings, each with its own Ring Keypad chime or tone and volume. Leave any slot’s trigger list empty to disable it.
- Keypad Motion Actions (Optional): Run custom actions when the keypad detects motion, regardless of Alarmo’s state.
- Instant Silence “Kill-Switch”: Typing your code and pressing ‘Disarm’ will instantly force the keypad to silence any sounding sirens, regardless of the current state of Alarmo.
- Brute Force Protection: Triggers the burglar alarm if someone tries to guess your PIN and fails too many times while the system is armed.
Credits
A huge thank you to ImSorryButWho for the original research on Z-Wave command classes and the foundational blueprint. This advanced version builds upon that foundation to fix silent alarms, synchronization race-conditions, add custom button mapping, interactable nottifications, optionally auto force arm on unresolved open sensors after a set delay.
Prerequisites
- A Ring Keypad V2 paired via Z-Wave JS.
IMPORTANT: It MUST be paired using S2 Security (S2 Access Control). If it is paired with no security or legacy S0, the keypad buttons and sirens will not function correctly! - Alarmo installed and configured in Home Assistant. (If you use environmental sensors, be sure to add them to Alarmo’s environmental category too).
- Alarmo “Disarm after triggering” option disabled.
- Counter Helper (Optional): If you wish to use the Brute Force Protection feature, you must create a Counter helper in Home Assistant (instructions below).
To configure custom sounds, add your triggers to Custom Sound Slot 1, 2, or 3, then set that slot’s sound and volume. The blueprint routes triggers based on which slot they are configured in, so you do not need to assign trigger IDs. Leave unused trigger lists empty. You can assign multiple triggers to the same slot to play the same sound for each.
To configure motion actions, open Keypad Motion Actions (Optional) and add your Motion Detected Actions (for example, turning on a light). If the motion sensor is disabled, enable it on the keypad’s device page first. Actions run when the keypad starts reporting motion, not continuously while motion remains detected. Leave actions empty to do nothing.
To configure presence-based behavior, select the people and zone to monitor, then add optional actions for when everyone arrives or everyone leaves. The automatic Away arm and arrival disarm toggles are independent and default off. Away arming only starts while Alarmo is disarmed and does not itself bypass open sensors. If arming fails because sensors are open, the existing Auto Force Arm on Open Sensors toggle determines whether its configured countdown starts; if enabled and the sensors remain unresolved, the alarm is force-armed after the countdown. With that toggle off, Alarmo remains disarmed after the failed attempt. Arrival disarming only runs while Alarmo is in an armed state. The optional mobile alarm code is shared with these automatic actions when Alarmo requires a code. Leaving the people selection empty disables presence-based actions.
Installation
The easiest way to install this blueprint is by clicking the import button below:
Manual installation:
If you prefer to install it manually:
- In Home Assistant, go to your
config/blueprints/automationfolder. - Create a new file called
ring_keypad_v2_advanced.yamland paste the raw code from this repository. - Go to Developer Tools → YAML → Reload Automations.
Setting up Brute Force Protection (Optional)
To enable the feature that triggers the alarm after too many failed PIN attempts, you need to create a simple Counter Helper in Home Assistant:
- Go to Settings → Devices & Services → Helpers or click the helpers button below.
- Click + Create Helper and select Counter.
- Name it something like “Keypad Failed Attempts” and leave the rest as default.
- When setting up this blueprint, toggle “Brute Force Protection” to true, select your newly created Counter entity, and choose your maximum allowed attempts.
How the Post-Alarm Warning Works
The Ring Keypad hardware prioritizes the Burglar siren. To ensure the post-alarm warning works, this blueprint will:
- Wait for Alarmo’s siren timer to expire.
- Officially send the “Armed Away/Home” command to the keypad to kill the siren.
- Wait exactly 6 seconds for the keypad to finish its voice prompt (“Away and Armed”).
- Send the raw
invoke_cc_apicommand to flash the Medical light permanently until you disarm the system.
Note on Panic Buttons
To prevent conflicting states, the physical Fire, Police, and Medical buttons are programmed to be ignored if your alarm system is currently in the pending (Entry Delay) or triggered (Siren Sounding) states.
Support / Issue Reports
If you run into a problem or want to report an issue, please open a ticket on: GitHub Issues
