Nobody likes being brutally interrupted by the TTS message when listening to the music, neither do I. So I wrote a script(with original idea borrowed from here) that pauses the music, announce the message and then resume the playing. The script in the above link does a good job with a little bit modification.
However, the problem with the script is that the music is always brutally interrupted. Therefore, I added a fade out effect using while loop before playing the TTS and it worked well.
The next problem is how to fade-in the volume when the play is resumed. The service being called to restore is sonos.restore
which will set the volume immediately to its previous value. My plan is, after sonos.store
, the volume is immediately set to 0, and then increased to its original value. This means I need a way to persist variable among the sequences, like this
sequences:
- service: sonos.restore
entity_id: media_player.bedroom_speaker
# Save the volume to a template variable? How?
# Something like
# {% set old_volume = states.media_player['bedroom_speaker'].attributes['volume_level'] %}
# Mute the speaker
- service: media_player.set_volume
volume_level: 0
# Then increase the volume gradually to its **Previous Value**
For anyone who wants to try the version without face-in
effect, here’s the YAML I came up with:
# > SONOS TTS
sonos_say:
alias: "Sonos TTS script"
fields:
sonos_entity:
description: "The eneity of the sonos"
example: "bedroom_speaker"
default: "bedroom_speaker"
message:
description: "The message content"
example: "The light is on!"
default: "Test message"
volume:
description: "The volume"
example: "0.5"
default: 0.5
sequence:
- service: sonos.snapshot
data_template:
entity_id: "{{ 'media_player.' ~ sonos_entity }}"
# Lower the volume gradually
- repeat:
while: "{{ states.media_player[sonos_entity].attributes['volume_level'] > 0 }}"
sequence:
- service: media_player.volume_set
data_template:
volume_level: >
{% set n = states.media_player[sonos_entity].attributes['volume_level'] %}
{{(n - 0.05) if (n - 0.05) > 0 else 0}}
- delay:
milliseconds: 100
- service: sonos.unjoin
data_template:
data_template:
volume_level: "{{ volume }}"
- service: tts.google_say
data_template:
message: "{{ message }}"
- delay: "00:00:01"
- delay: >-
{% set duration = states.media_player[sonos_entity].attributes.media_duration %}
{% if duration > 0 %}
{% set duration = duration - 1 %}
{% endif %}
{% set seconds = duration % 60 %}
{% set minutes = (duration / 60)|int % 60 %}
{% set hours = (duration / 3600)|int %}
{{ [hours, minutes, seconds]|join(':') }}
- delay: "00:00:05"
data_template:
